查看: 1659|回复: 10
[技术探讨] 自动化新建 或者 修改 保存 还是报500错误,大家找到方法....
发表于 2025-3-27 15:44:31 | 显示全部楼层 |阅读模式
上个月 升级后 自动化新建 或者 修改 保存 就报500错误,不能保存,只有在core提示更新后,重启的短暂时间可以保存,前天Operating System 提示更新,现在是15.0的版本了,自动化还是报500错误,大家找到解决办法没有??
试过把自动化名称改成拼音,还是不管用。
发表于 2025-3-27 16:38:48 | 显示全部楼层
没有日志老衲只能给你算上一卦了
jjcs 手机认证
发表于 2025-3-27 18:25:27 | 显示全部楼层
 楼主| 发表于 2025-3-27 18:48:24 | 显示全部楼层
ryanh7 发表于 2025-3-27 16:38
没有日志老衲只能给你算上一卦了
是不是 这个 日志
 楼主| 发表于 2025-3-27 18:52:40 | 显示全部楼层
日志记录器: aiohttp.server
来源: /usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py:451
首次出现: 2025年3月26日 13:46:18 (24 次总计出现)
上次记录: 18:51:05
Error handling request from 192.168.3.127
Error handling request from 192.168.3.92
Error handling request from 192.168.3.90
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py", line 480, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_app.py", line 569, in _handle
    return await handler(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_middlewares.py", line 117, in impl
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 83, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 86, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware
    response = await handler(request)
  File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
    result = await handler(request, **request.match_info)
  File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 973, in get
    return await self.handle(request, camera)
  File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 991, in handle
    image = await _async_get_image(
    ...<4 lines>...
  File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 205, in _async_get_image
    else await camera.async_camera_image(width=width, height=height)
  File "/config/custom_components/dahua/camera.py", line 253, in async_camera_image
    return await self._coordinator.client.async_get_snapshot(self._channel_number)
  File "/config/custom_components/dahua/client.py", line 75, in async_get_snapshot
    return await self.get_bytes(url)
  File "/config/custom_components/dahua/client.py", line 780, in get_bytes
    response.raise_for_status()
  File "/usr/local/lib/python3.13/site-packages/aiohttp/client_reqrep.py", line 1161, in raise_for_status
    raise ClientResponseError(
    ...<5 lines>...
aiohttp.client_exceptions.ClientResponseError: 401, message='Unauthorized', url='http://192.168.3.224/cgi-bin/snapshot.cgi?channel=1'
 楼主| 发表于 2025-3-27 18:54:49 | 显示全部楼层
首次出现: 18:08:52 (102 次总计出现)
上次记录: 18:54:13
  File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 81, in with_admin
    return await func(self, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/config/view.py", line 134, in post
    await hass.async_add_executor_job(_write, path, current)
  File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 59, in run
  File "/usr/src/homeassistant/homeassistant/components/config/view.py", line 251, in _write
    write_utf8_file_atomic(path, contents)
  File "/usr/src/homeassistant/homeassistant/util/file.py", line 39, in write_utf8_file_atomic
    fdesc.write(utf8_data)
UnicodeEncodeError: 'ascii' codec can't encode characters in position 31-36: ordinal not in range(128)
发表于 2025-3-27 20:37:23 | 显示全部楼层
来源: /usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py:451 ...
这个错误不知道是不是和你的500错误同时出现的,不知道是否相关。但这个错误很可能是由于系统环境的语言设置不正确(未设置utf-8),导致配置模块写入utf8的配置文件的时候错误地尝试使用ascii编码,从而引发错误。由于不清楚你的安装方式,建议往设置utf8的系统语言环境方向尝试。
 楼主| 发表于 2025-3-27 21:13:26 | 显示全部楼层
ryanh7 发表于 2025-3-27 20:37
这个错误不知道是不是和你的500错误同时出现的,不知道是否相关。但这个错误很可能是由于系统环境的语言 ...
pve 虚拟机 冬瓜 系统 以前都是正常的 就是 升级 后才出现的这个问题
 楼主| 发表于 2025-3-27 21:19:00 | 显示全部楼层
请教大神 如何设置 已经一个多月了。这个错误是和500错误同时出现的。
 楼主| 发表于 2025-3-27 21:58:45 | 显示全部楼层
automations.yaml  configuration.yaml 把这两个另存为 utf-8 重启了 好像好了
GMT+8, 2026-1-15 15:08 , Processed in 0.742041 second(s), 10 queries , MemCached On.
