楼主: a.Dong
[插件集成] 【重磅发布】Home Assistant 应用商店 !它来了!
发表于 2025-6-25 12:52:38 | 显示全部楼层
感谢分享,试试看
发表于 2025-8-5 14:41:21 | 显示全部楼层
谢谢分享~~期待电网
发表于 2025-8-5 16:28:28 | 显示全部楼层
内容太少了
发表于 2025-8-7 22:14:08 | 显示全部楼层
给大佬点根烟
发表于 2025-9-5 07:28:53 | 显示全部楼层
今天 升级 Core 2025.9.0 后 hassbox 无法加载
日志记录器: homeassistant.setup
来源: setup.py:343
首次出现: 07:28:01 (1 次出现)
上次记录: 07:28:01
Setup failed for custom integration 'hassbox_store': Unable to import component: cannot import name 'json_loads' from 'homeassistant.helpers.json' (/usr/src/homeassistant/homeassistant/helpers/json.py)
  File "/usr/src/homeassistant/homeassistant/loader.py", line 1003, in async_get_component
    comp = await self.hass.async_add_import_executor_job(
        self._get_component, True
  File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 59, in run
  File "/usr/src/homeassistant/homeassistant/loader.py", line 1063, in _get_component
    ComponentProtocol, importlib.import_module(self.pkg_path)
  File "/usr/src/homeassistant/homeassistant/util/loop.py", line 201, in protected_loop_func
    return func(*args, **kwargs)
  File "/usr/local/lib/python3.13/importlib/__init__.py", line 88, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
  File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
  File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 1026, in exec_module
  File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
  File "/config/custom_components/hassbox_store/__init__.py", line 20, in <module>
    from .base import HassBoxStore
  File "/config/custom_components/hassbox_store/base.py", line 39, in <module>
    from .utils.json import json_loads
  File "/config/custom_components/hassbox_store/utils/json.py", line 3, in <module>
    from homeassistant.helpers.json import json_loads
ImportError: cannot import name 'json_loads' from 'homeassistant.helpers.json' (/usr/src/homeassistant/homeassistant/helpers/json.py)
  File "/usr/src/homeassistant/homeassistant/setup.py", line 343, in _async_setup_component
    component = await integration.async_get_component()
  File "/usr/src/homeassistant/homeassistant/loader.py", line 1023, in async_get_component
    self._component_future.result()
  File "/usr/src/homeassistant/homeassistant/loader.py", line 1015, in async_get_component
    comp = self._get_component()
发表于 2025-9-5 10:54:14 | 显示全部楼层
支持!顶起来,安装中。。。。
发表于 2025-10-10 09:47:05 | 显示全部楼层
安装试试
发表于 2025-10-10 14:31:05 | 显示全部楼层
楼主牛逼。马上下载用
发表于 2025-10-10 14:35:42 | 显示全部楼层
大佬,加载不了 啊
发表于 2025-10-11 15:26:55 | 显示全部楼层
lslxgh 发表于 2025-10-10 14:35
大佬,加载不了 啊
GMT+8, 2026-1-15 08:35 , Processed in 0.260966 second(s), 15 queries , MemCached On.
