查看: 1513|回复: 3
[求助] esphome升级到2025.2后,文本传感器自定义问题
发表于 2025-3-6 20:04:48 | 显示全部楼层 |阅读模式
esphome升级到2025.2后,文本传感器自定义编译不能通过,看了文档也没弄明白。哪位大神指教一下,谢谢!
具体代码如下:
esphome:
  friendly_name: kit-light
  includes:
    - su03t_uart_read.h
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
#api:
#  encryption:
#   key: "uFZJJX8pBd/OeHsSKZ9Sg9hggff554q/Wshm5h/LrSDFhw="
ota:
  - platform: esphome
    password: "zxxxgzm13524"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Kit-Light Fallback Hotspot"
    password: "cyJbBerQp0Wr"
captive_portal:
web_server:                     #网页web显示
  port: 80
mqtt:
  broker: 192.168.1.22 # mqtt服务器ip/域名
  username: mqtt # 账号
  password: mqtt # 密码
uart:
  - id: uart_bus_cmd
    rx_pin: GPIO5  #根据实际接线修改gpio
    baud_rate: 9600
text_sensor:
  - platform: custom
    lambda: |-
      auto my_custom_sensor = new UartReadLineSensor(id(uart_bus_cmd));
      App.register_component(my_custom_sensor);
      return {my_custom_sensor};
    text_sensors:
编译时显示错误是:
INFO ESPHome 2025.2.0INFO Reading configuration config\kit-light.yaml...Failed configtext_sensor.custom: [source config\kit-light.yaml:51]    The "custom" component has been removed. Consider conversion to an external component.  https://esphome.io/guides/contri ... -custom-components.  platform: custom  lambda: |-    auto my_custom_sensor = new UartReadLineSensor(id(uart_bus_cmd));    App.register_component(my_custom_sensor);    return {my_custom_sensor};  text_sensors:     name: su03t_cmd
请哪位大神指教为感
发表于 2025-3-6 22:43:59 | 显示全部楼层
custom component 已经被移除了,需要迁移到 external component
 楼主| 发表于 2025-3-7 11:47:22 | 显示全部楼层
自定义那一块应该怎样写呢?谢谢
发表于 2025-3-8 21:41:07 | 显示全部楼层
要重写的很多,不只一个yaml的问题,还是找别人改好的吧
没编程基础自己搞很难
GMT+8, 2025-12-17 04:34 , Processed in 0.052327 second(s), 11 queries , MemCached On.
