查看: 1263|回复: 0
[基础教程] 冬瓜os虚拟机安装问题
发表于 2025-3-5 20:09:00 | 显示全部楼层 |阅读模式
[color=var(--success-color)]2025-03-05 20:07:37.634 INFO (MainThread) [supervisor.docker.interface] Updating image m.tonbcr.com/home-assistant/qemux86-64-homeassistant:landingpage to m.tonbcr.com/home-assistant/qemux86-64-homeassistant:2025.2.5
[color=var(--success-color)]2025-03-05 20:07:37.634 INFO (MainThread) [supervisor.docker.interface] Downloading docker image m.tonbcr.com/home-assistant/qemux86-64-homeassistant with tag 2025.2.5.
[color=var(--error-color)]2025-03-05 20:07:48.536 ERROR (MainThread) [supervisor.docker.interface] Can't install m.tonbcr.com/home-assistant/qemux86-64-homeassistant:2025.2.5: 404 Client Error for http+docker://localhost/v1.47/images/m.tonbcr.com/home-assistant/qemux86-64-homeassistant:2025.2.5/json: Not Found ("No such image: m.tonbcr.com/home-assistant/qemux86-64-homeassistant:2025.2.5")
[color=var(--warning-color)]2025-03-05 20:07:48.537 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
提示的就是这个,看着是网络问题。。但是用了科学也不行,有大佬知道什么情况嘛
GMT+8, 2025-11-30 11:51 , Processed in 0.060131 second(s), 10 queries , MemCached On.
