查看: 1538|回复: 3
[技术探讨] zigbee2mqtt 启动不了,麻烦帮我研究一下!!
发表于 2025-3-2 13:10:19 | 显示全部楼层 |阅读模式
Starting Zigbee2MQTT without watchdog.
[2025-03-02 13:08:43] [color=var(--success-color)]info:         z2m: Logging to console, file (filename: log.log)
[2025-03-02 13:08:43] [color=var(--success-color)]info:         z2m: Starting Zigbee2MQTT version 2.1.1 (commit #unknown)
[2025-03-02 13:08:43] [color=var(--success-color)]info:         z2m: Starting zigbee-herdsman (3.2.5)
[2025-03-02 13:08:43] [color=var(--success-color)]info:         zh:zstack:znp: Opening TCP socket with 192.168.3.114:6638
[2025-03-02 13:08:43] [color=var(--success-color)]info:         zh:zstack:znp: Socket connected
[2025-03-02 13:08:43] [color=var(--success-color)]info:         zh:zstack:znp: Socket ready
[2025-03-02 13:08:43] [color=var(--success-color)]info:         zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2025-03-02 13:08:44] [color=var(--success-color)]info:         zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2025-03-02 13:08:44] [color=var(--error-color)]error:         zh:adapter:zstack:manager: Configuration is not consistent with adapter state/backup!
[2025-03-02 13:08:44] [color=var(--error-color)]error:         zh:adapter:zstack:manager: - PAN ID: configured=30949, adapter=59755
[2025-03-02 13:08:44] [color=var(--error-color)]error:         zh:adapter:zstack:manager: - Extended PAN ID: configured=cd62a7c84481a9d6, adapter=71f40e631cb06ff6
[2025-03-02 13:08:44] [color=var(--error-color)]error:         zh:adapter:zstack:manager: - Network Key: configured=1e8ce73fb8f2f93566fd4d2c9cd3175a, adapter=e166918ebf62ee94e262236e12fe4532
[2025-03-02 13:08:44] [color=var(--error-color)]error:         zh:adapter:zstack:manager: - Channel List: configured=11, adapter=11
[2025-03-02 13:08:44] [color=var(--error-color)]error:         zh:adapter:zstack:manager: Please update configuration to prevent further issues.
[2025-03-02 13:08:44] [color=var(--error-color)]error:         zh:adapter:zstack:manager: If you wish to re-commission your network, please remove coordinator backup at /config/zigbee2mqtt/coordinator_backup.json.
[2025-03-02 13:08:44] [color=var(--error-color)]error:         zh:adapter:zstack:manager: Re-commissioning your network will require re-pairing of all devices!
[2025-03-02 13:08:44] [color=var(--error-color)]error:         z2m: Error while starting zigbee-herdsman
[2025-03-02 13:08:44] [color=var(--error-color)]error:         z2m: Failed to start zigbee-herdsman
[2025-03-02 13:08:44] [color=var(--error-color)]error:         z2m: Check https://www.zigbee2mqtt.io/guide ... rashes-runtime.html for possible solutions
[2025-03-02 13:08:44] [color=var(--error-color)]error:         z2m: Exiting...
[2025-03-02 13:08:44] [color=var(--error-color)]error:         z2m: Error: startup failed - configuration-adapter mismatch - see logs above for more information
    at ZnpAdapterManager.determineStrategy (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:252:35)
    at processTicksAndRejections (node:internal/process/task_queues:105:5)
    at ZnpAdapterManager.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:62:26)
    at ZStackAdapter.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:158:16)
    at Controller.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/controller/controller.ts:136:29)
    at Zigbee.start (/app/lib/zigbee.ts:69:27)
    at Controller.start (/app/lib/controller.ts:142:13)
    at start (/app/index.js:161:5)
发表于 2025-3-2 14:01:41 | 显示全部楼层
适配器配置与备份不匹配 的错误,导致 zigbee-herdsman 无法正常启动
 楼主| 发表于 2025-3-2 16:04:03 | 显示全部楼层
这个怎么搞
 楼主| 发表于 2025-3-2 20:57:22 | 显示全部楼层
已经搞定了。
GMT+8, 2026-1-15 10:15 , Processed in 1.273063 second(s), 7 queries , MemCached On.
