查看: 2543|回复: 4
[技术探讨] 联通app话费查询方法~
发表于 2025-2-21 23:40:51 | 显示全部楼层 |阅读模式
原理:
1.通过模拟登录、获取数据并保持会话活跃的功能, Flask 创建了一个简单的 Web 服务  2.然后通过ha的nodered获取数据~
需要抓取的包
1.心跳包.
2.话费页面的包.
需要修改的数据是:
# 可直接修改的变量
TOKEN_ONLINE = "your_token_online_value"
APP_ID = "your_app_id_value"
DEVICE_CODE = "your_device_code_value"
DESMOBIEL = "your_desmobiel_value"
HEARTBEAT_DATA = "your_heartbeat_data_value"
一.步骤1.下面是现实的代码:
from flask import Flask, jsonify
import requests
import time
app = Flask(__name__)
# 可直接修改的变量
def simulate_login_and_get_data():
    # 建立会话,自动保存和传递 cookies
    session = requests.Session()
    # 通用请求头
    headers = {
        "User-Agent": "ChinaUnicom.x CFNetwork iOS/18.0 unicom{version:[email protected]}",
        "Accept": "*/*",
        "Accept-Language": "zh-CN,zh-Hans;q=0.9",
        "Accept-Encoding": "gzip, deflate, br",
    # 登录接口的 URL
    login_url = "https://m.client.10010.com/mobileService/onLine.htm"
    # 登录 POST 请求的表单数据
    login_data = {
        "reqtime": "2025-02-20 14:44:14",
        "version": "[email protected]",
        "token_online": TOKEN_ONLINE,  # 使用可变变量
        "longitude": "113.225391",
        "appId": APP_ID,  # 使用可变变量
        "deviceId": "5cf194efdf7acaa8e86b22d0add453b8ced10a2cac56fd2934fb16db75739ed2",
        "latitude": "23.421746",
        "deviceModel": "iPhone",
        "step": "background",
        "isFirstInstall": "1",
        "deviceCode": DEVICE_CODE,  # 使用可变变量
    # 构造登录请求头(需指定 Content-Type)
    login_headers = headers.copy()
    login_headers.update({
        "Content-Type": "application/x-www-form-urlencoded",
        "Connection": "keep-alive"
    # 发送登录请求
    login_resp = session.post(login_url, headers=login_headers, data=login_data)
    if login_resp.status_code != 200:
        return None, "登录失败,状态码:" + str(login_resp.status_code)
    # 登录后使用同一个 session 发送 GET 请求获取业务数据
    data_url = "https://m.client.10010.com/mobileserviceimportant/home/queryUserInfoSeven"
    params = {
        "desmobiel": DESMOBIEL,  # 使用可变变量
        "showType": "0"
    data_resp = session.get(data_url, headers=headers, params=params)
    if data_resp.status_code == 200:
        try:
            json_data = data_resp.json()
            return json_data, None
        except Exception as e:
            return None, "解析 JSON 失败:" + str(e)
    else:
        return None, "数据获取失败,状态码:" + str(data_resp.status_code)
def send_heartbeat(session):
    发送心跳包请求,保持会话活跃
    heartbeat_url = "https://playback.newbuy.chinaunicom.cn/dcnew/webinsight/data"
    params = {
        "time": str(int(time.time() * 1000))  # 使用当前的时间戳(单位毫秒)
    heartbeat_headers = {
        "Host": "playback.newbuy.chinaunicom.cn",
        "Accept": "*/*",
        "Sec-Fetch-Site": "cross-site",
        "Cache-Control": "max-age=0",
        "Sec-Fetch-Mode": "no-cors",
        "Origin": "https://img.client.10010.com",
        "User-Agent": "Mozilla/5.0 (iPhone; CPU iPhone OS 17_3_1 like Mac OS X) AppleWebKit/605.1.15 (KHTML, like Gecko) Mobile/15E148 unicom{version:[email protected]}",
        "Referer": "https://img.client.10010.com/",
        "Connection": "keep-alive",
        "Content-Type": "text/plain;charset=UTF-8",
        "Sec-Fetch-Dest": "empty"
    heartbeat_data = HEARTBEAT_DATA  # 使用可变变量
    session.post(heartbeat_url, headers=heartbeat_headers, params=params, data=heartbeat_data)
@app.route('/api/get_data', methods=['GET'])
def get_data():
    # 模拟登录,获取数据
    json_data, error = simulate_login_and_get_data()
    if error:
        return jsonify({"error": error}), 400
    # 发送心跳包,保持会话活跃
    # 提取所需的字段
    response_data = {
        "flush_date_time": json_data.get("flush_date_time", ""),
        "feePersent": json_data.get("feeResource", {}).get("feePersent", ""),
        "flowPersent": json_data.get("flowResource", {}).get("flowPersent", "")
    return jsonify(response_data)
if __name__ == '__main__':
    app.run(host='0.0.0.0', port=9996)
二.步骤2.
导入nodered
flows.rar
1.34 KB, 下载次数: 4
参与人数 1金钱 +12 收起 理由
隔壁的王叔叔 + 12 感谢楼主分享!
发表于 2025-2-22 09:02:19 来自手机 | 显示全部楼层
不要短信验证码?
 楼主| 发表于 2025-2-22 21:05:11 | 显示全部楼层
wangling75 发表于 2025-2-22 09:02
不要短信验证码?
要先登录,然后抓包,现在一个月token还有效....
发表于 2025-2-22 23:21:15 | 显示全部楼层
直接python script搞定呗,通过nr中转岂不麻烦些
发表于 2025-5-8 14:26:17 来自手机 | 显示全部楼层
可以做成集成吗
GMT+8, 2026-1-15 16:56 , Processed in 0.605463 second(s), 8 queries , MemCached On.
