查看: 1787|回复: 8
[求助] 2025ESP出错TDS
发表于 2025-2-20 08:15:49 | 显示全部楼层 |阅读模式
更新最新版后,改了几个规则,TDS出错。有大佬帮看下点修改?感谢。
#sensor:
  - platform: custom
    lambda: |-
      auto tds_sensor = new TDSSensorComponent(id(uart_bus1));
      App.register_component(tds_sensor);
      return {tds_sensor->tds1,tds_sensor->temperature1,tds_sensor->tds2,tds_sensor->temperature2};
    sensors:
      - name: "tds1"
        unit_of_measurement: ppm
        accuracy_decimals: 1
      - name: "temperature1"
        unit_of_measurement: °C
        accuracy_decimals: 2
      - name: "tds2"
      - name: "temperature2"
发表于 2025-2-20 09:03:04 | 显示全部楼层
DS-R1改的,不知道对不对:
  - platform: custom
    lambda: |-
      return std::vector<sensor::Sensor*>{
        tds_sensor->tds1,
        tds_sensor->tds2,
    sensors:
      tds1:
        name: "TDS Sensor 1"
        unit_of_measurement: "ppm"
      temperature1:
        unit_of_measurement: "°C"
      tds2:
        name: "TDS Sensor 2"
      temperature2:
修改说明:
使用std::vector<sensor::Sensor*>明确返回类型,避免类型推导错误
采用键值对形式声明传感器配置,符合新版配置规范
移除冗余的id声明(自定义组件已自带唯一标识)
建议为每个传感器添加更详细的name描述
字符串类型的单位声明需使用双引号包裹
若问题仍未解决,请检查:
UART总线配置是否正确(波特率/引脚定义)
自定义组件TDSSensorComponent是否适配最新版ESPHome API
确保在全局配置中正确定义了uart_bus1:
uart:
  - id: uart_bus1
    tx_pin: GPIOXX
    rx_pin: GPIOXX
    baud_rate: XXXX
发表于 2025-2-20 11:17:49 | 显示全部楼层
你這個代碼跟我的一模一樣
難道也是用GhatGPT寫的
 楼主| 发表于 2025-2-23 17:56:14 | 显示全部楼层
落楓 发表于 2025-2-20 09:03
DS-R1改的,不知道对不对:
修改说明:
感谢。。。。。
 楼主| 发表于 2025-2-23 18:18:42 | 显示全部楼层
DS-R1改的,不知道对不对:
修改说明:
好像还是出错。INFO ESPHome 2025.2.0INFO Reading configuration /config/esphome/water1.yaml...Failed configsensor.custom: [source /config/esphome/water1.yaml:82]    The "custom" component has been removed. Consider conversion to an external component.  https://esphome.io/guides/contri ... -custom-components.  platform: custom  lambda: |-    auto tds_sensor = new TDSSensorComponent(id(uart_bus1));    App.register_component(tds_sensor);    return std::vector<sensor::Sensor*>{      tds_sensor->tds1,      tds_sensor->temperature1,      tds_sensor->tds2,      tds_sensor->temperature2    };  sensors:
发表于 2025-2-24 10:09:00 | 显示全部楼层
好像是自定义组件不再支持了,我的也无法更新了
 楼主| 发表于 2025-3-4 19:49:38 | 显示全部楼层
找到解决方法了吗?
发表于 2025-3-6 20:11:38 | 显示全部楼层
是自定义被删了,不支持了。我的也是这样,看文档是使用外部组件,还没搞清楚呢
 楼主| 发表于 2025-3-6 20:25:04 | 显示全部楼层
bhc1365 发表于 2025-3-6 20:11
是自定义被删了,不支持了。我的也是这样,看文档是使用外部组件,还没搞清楚呢 ...
官方好像没看到有支持TDS的文档。不知道为什么,真奇怪
GMT+8, 2025-12-17 06:38 , Processed in 0.438597 second(s), 5 queries , MemCached On.
