查看: 1180|回复: 3
WGHAOS SSH 配置器 无法启用端口22222
发表于 2025-2-15 09:54:39 | 显示全部楼层 |阅读模式
小白正在折腾HA, 别人送了一个 官网的ha green小主机
我安装了WGHAOS SSH 配置器插件,但是HAOS没有启用22222端口,无法ssh连接
请问这是插件不支持新的系统版本吗?日志如下
[color=var(--info-color)]----------------------------------------------------------
[color=var(--success-color)]Starting....
[color=var(--info-color)] Add-on: WGHAOS SSH 配置器
[color=var(--info-color)] 这将启用端口22222上的SSH WGHassOS控制台。仅适用于Home Assistant操作系统
[color=var(--info-color)]-----------------------------------------------------------
[color=var(--info-color)] Add-on version: 0.2.4
[color=var(--success-color)] You are running the latest version of this add-on.
project name:  wghaosssh
[GIN-debug] [WARNING] Running in "debug" mode. Switch to "release" mode in production.
- using env:        export GIN_MODE=release
- using code:        gin.SetMode(gin.ReleaseMode)
[GIN-debug] GET    /healthCheck              --> wg-hassio-base/controller.HealthCheck (4 handlers)
[GIN-debug] POST   /hello                    --> wg-hassio-base/controller.Hello (4 handlers)
[GIN-debug] POST   /createKeys               --> wg-hassio-base/controller.CreateKeys (4 handlers)
[GIN-debug] GET    /ping                     --> wg-hassio-base/controller.Ping (4 handlers)
[GIN-debug] GET    /indexList                --> wg-hassio-base/controller.IndexList (4 handlers)
[GIN-debug] POST   /deleteKeys               --> wg-hassio-base/controller.DeleteKeys (4 handlers)
[GIN-debug] GET    /saveAppKeys              --> wg-hassio-base/controller.SaveAppKeys (4 handlers)
[GIN-debug] GET    /initSettings             --> wg-hassio-base/controller.InitSettingsKeys (4 handlers)
[GIN-debug] [WARNING] You trusted all proxies, this is NOT safe. We recommend you to set a value.
Please check https://pkg.go.dev/github.com/gi ... t-trust-all-proxies for details.
[GIN-debug] Listening and serving HTTP on :9876
[color=var(--info-color)] System: Home Assistant OS 13.2  (aarch64 / green)
[color=var(--info-color)] Home Assistant Core: 2025.2.2
[color=var(--info-color)] Home Assistant Supervisor: 2025.02.1
[color=var(--info-color)] Please, share the above information when looking for help
[color=var(--info-color)] or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service base-addon-log-level successfully started
mounted to %s %s %s: /dev/mmcblk0p7 false /mnt/root
发表于 2025-2-15 10:07:44 | 显示全部楼层
我也不能用,冬瓜os
 楼主| 发表于 2025-2-15 13:24:45 | 显示全部楼层
后面用 加速器插件 科学上网安装了自带仓库的SSH
发表于 2025-2-22 22:07:55 | 显示全部楼层
安卓手机app server box无法通过ssh获取haos的系统信息,怎么操作?求助
GMT+8, 2026-1-17 05:39 , Processed in 1.253266 second(s), 7 queries , MemCached On.
