查看: 1100|回复: 0
[求助] esphome新项目编译
发表于 2025-2-12 20:13:27 | 显示全部楼层 |阅读模式
如图,新建立的esphome工程下载安装:esphome/ESPAsyncTCP-esphome @ 2.0.0时
显示错误,哪位大佬遇到过
WARNING Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0x7fdb85c21f90>: Failed to resolve 'api.registry.platformio.org' ([Errno -3] Temporary failure in name resolution)")': /v3/packages/esphome/library/espasynctcp-esphome
GMT+8, 2025-12-18 15:04 , Processed in 1.053375 second(s), 6 queries , MemCached On.
