查看: 1215|回复: 3
[技术讨论] 智能开关转无线后如何触发自动化
发表于 2025-2-9 00:40:49 | 显示全部楼层 |阅读模式
刚装好hass不久,gateway3接入墙壁的零火开关发现不识别。经历曲折,自己写了适配的代码,终于能正常控制继电器和实现sensor接收数据了。
然而现在的情况是,首次按下按钮后,sensor的状态会从未知变成single并保持不动,不再更新。所以后面的自动化也没办法写了。
想问问大家的智能开关有这种情况吗?大家有能正常实现在ha中转无线后触发自动化的吗,想问问大家的设备都是什么?或者有什么解决方案吗?
谢谢大家!
 楼主| 发表于 2025-2-9 00:44:16 | 显示全部楼层
like this
发表于 2025-2-9 23:39:17 | 显示全部楼层
这个是bug,正常single后,会清除重置,你得反馈给集成作者
 楼主| 发表于 2025-2-11 00:15:26 | 显示全部楼层
from custom_components.xiaomi_gateway3.core.devices import *
DEVICES = [{
    # https://home.miot-spec.com/spec/huca.switch.lh1
    15109: ["H+", "H+ zero fire single key switch", "huca.switch.lh1"],
    "spec": [
        BaseConv("action", "sensor"),
        ConstConv("action", mi="5.e.1", value=BUTTON_SINGLE),
        BaseConv("switch", "switch", mi="2.p.1"),
        BaseConv("backlight", "switch", mi="12.p.1"),  # config
        MapConv("mode", "select", mi="2.p.2", map={0: "Wired And Wireless", 1: "Wireless", 2: "Flex", 3: "Jog"}),
    # https://home.miot-spec.com/spec/huca.switch.lh2
    15110: ["H+", "H+ zero fire double key switch", "huca.switch.lh2"],
    "spec": [
        ConstConv("action", mi="5.e.1", value=BUTTON_1_SINGLE),
        ConstConv("action", mi="6.e.1", value=BUTTON_2_SINGLE),
        BaseConv("switch_1", "switch", mi="2.p.1"),
        BaseConv("switch_2", "switch", mi="3.p.1"),
        MapConv("mode_1", "select", mi="2.p.2", map={0: "Wired And Wireless", 1: "Wireless", 2: "Flex", 3: "Jog"}),
        MapConv("mode_2", "select", mi="3.p.2", map={0: "Wired And Wireless", 1: "Wireless", 2: "Flex", 3: "Jog"}),
    # https://home.miot-spec.com/spec/huca.switch.lh3
    15111: ["H+", "H+ zero fire tripl key switch", "huca.switch.lh3"],
    "spec": [
        ConstConv("action", mi="7.e.1", value=BUTTON_3_SINGLE),
        BaseConv("switch_3", "switch", mi="4.p.1"),
        MapConv("mode_3", "select", mi="4.p.2", map={0: "Wired And Wireless", 1: "Wireless", 2: "Flex", 3: "Jog"}),
}] + DEVICES
问题已解决,不知道什么原因,但是action相关的代码改成这样就可以正常清除重置了。
GMT+8, 2025-12-15 23:59 , Processed in 1.004086 second(s), 16 queries , MemCached On.
