查看: 2331|回复: 1
[求助] esp32 IR Receiver与连接WIFI有冲突
发表于 2025-2-5 21:18:39 | 显示全部楼层 |阅读模式
计划使用esp32来读取IR Receiver接收到的数据。但是每次烧录后就不能连接WiFi,也无法接收遥控器发射的红外编码。
[21:01:54]n...[21:01:54][W][component:157]: Component wifi set Warning flag: scanning for networks[21:01:54][D][wifi:497]: Found networks:[21:01:54][I][wifi:541]: - 'ChinaNet-5Yag' (64:52:34:14:CA:50) [redacted]▂▄▆█[21:01:54][D][wifi:542]:     Channel: 1[21:01:54][D][wifi:543]:     RSSI: -61 dB[21:01:54][D][wifi:546]: - 'ChinaNet-Cwi6'[redacted] (04:75:F9:AA:21:54) [redacted]▂▄▆█[21:01:54][D][wifi:546]: - '181******57的P40'[redacted] (8E:44:53:A8:3BB) [redacted]▂▄▆█[21:01:54][D][wifi:546]: - 'GeXing_BA3E'[redacted] (E4:7D:EB:C3:BA:3E) [redacted]▂▄▆█[21:01:54][I][wifi:313]: WiFi Connecting to 'ChinaNet-5Yag'...[21:01:58][W][wifi:663]: WiFi network can not be found anymore.[21:01:58][W][wifi_esp32:542][arduino_events]: Event: Disconnected ssid='ChinaNet-5Yag' reason='Probe Request Unsuccessful'[21:01:58][D][wifi:697]: Retrying with hidden networks...[21:02:03][I][wifi:313]: WiFi Connecting to 'ChinaNet-5Yag'...[21:02:03][W][wifi:663]: WiFi network can not be found anymore.[21:02:03][I][wifi:313]: WiFi Connecting to 'ChinaNet-5Yag'...[21:02:03][W][wifi:663]: WiFi network can not be found anymore.[21:02:05][W][wifi_esp32:545][arduino_events]: Event: Disconnected ssid='ChinaNet-5Yag' bssid=64:52:34:14:CA:50[redacted] reason='Auth Expired'[21:02:08][I][wifi:313]: WiFi Connecting to 'ChinaNet-5Yag'...[21:02:08][W][wifi:653]: Error while connecting to network.[21:02:08][D][wifi:697]: Retrying with hidden networks...[21:02:08][I][wifi:313]: WiFi Connecting to 'ChinaNet-5Yag'...[21:02:08][W][wifi:663]: WiFi network can not be found anymore.[21:02:08][D][wifi:697]: Retrying with hidden networks...[21:02:10][W][wifi_esp32:545][arduino_events]: Event: Disconnected ssid='ChinaNet-5Yag' bssid=64:52:34:14:CA:50[redacted] reason='Auth Expired'[21:02:13][I][wifi:313]: WiFi Connecting to 'ChinaNet-5Yag'...[21:02:13][W][wifi:653]: Error while connecting to network.[21:02:13][W][wifi:690]: Restarting WiFi adapter...[21:02:13][I][wifi:313]: WiFi Connecting to 'ChinaNet-5Yag'...[21:02:13][I][remote.canalsat:103]: Received CanalSat: device=0x7F, address=0x3F, command=0x7F, repeat=0x1[21:02:13][I][remote.pronto:231]: Received Pronto: data=[21:02:13][I][remote.pronto:233]: 0000 006D 0003 0000 0008 0009 000C 0009 0014 0181 [21:02:13][I][remote.pronto:231]: Received Pronto: data=[21:02:13][I][remote.pronto:233]: 0000 006D 000C 0000 0007 0043 0019 0086 000C 0173 000A 0027 0007 0006 0004 0006 0002 0021 0008 0104 000B 0057 000F 00E8 0012 0067 000F 0181 [21:02:13][I][remote.pronto:231]: Received Pronto: data=[21:02:13][I][remote.pronto:233]: 0000 006D 0005 0000 0002 0008 0002 0027 000C 0040 000B 005B 001D 0181 [21:02:13][I][remote.pronto:231]: Received Pronto: data=[21:02:13][I][remote.pronto:233]: 0000 006D 0009 0000 0009 0017 0008 000B 0010 00D6 000A 012F 0009 0068 0002 0006 0014 0054 0031 0005 0007 0181 [21:02:15][W][wifi_esp32:545][arduino_events]: Event: Disconnected ssid='ChinaNet-5Yag' bssid=64:52:34:14:CA:50[redacted] reason='Auth Expired'[21:02:15][W][wifi:653]: Error while connecting to network.[21:02:15][D][wifi:697]: Retrying with hidden networks...[21:02:20][I][wifi:313]: WiFi Connecting to 'ChinaNet-5Yag'...[21:02:25][W][wifi_esp32:545][arduino_events]: Event: Disconnected ssid='ChinaNet-5Yag' bssid=64:52:34:14:CA:50[redacted] reason='Auth Expired'[21:02:25][W][wifi:653]: Error while connecting to network.[21:02:25][D][wifi:697]: Retrying with hidden networks...[21:02:25][I][wifi:313]: WiFi Connecting to 'ChinaNet-5Yag'...[21:02:26]����������������������������������������������������������������[0;33m[W][wifi_esp32:545][arduino_events]: Event: Disconnected ssid='ChinaNet-5Yag' bssid=64:52:34:14:CA:50[redacted] reason='Auth Expired'[21:02:26][W][wifi:653]: Error while connecting to network.[21:02:26][D][wifi:697]: Retrying with hidden networks...[21:02:31][I][wifi:313]: WiFi Connecting to 'ChinaNet-5Yag'...[21:02:36][W][wifi_esp32:545][arduino_events]: Event: Disconnected ssid='ChinaNet-5Yag' bssid=64:52:34:14:CA:50[redacted] reason='Auth Expired'[21:02:36][W][wifi:653]: Error while connecting to network.[21:02:36][D][wifi:697]: Retrying with hidden networks...[21:02:36][I][wifi:313]: WiFi Connecting to 'ChinaNet-5Yag'...[21:02:37][W][wifi_esp32:545][arduino_events]: Event: Disconnected ssid='ChinaNet-5Yag' bssid=64:52:34:14:CA:50[redacted] reason='Auth Expired'[21:02:37][W][wifi:653]: Error while connecting to network.[21:02:37][D][wifi:697]: Retrying with hidden networks...[21:02:42]����������������������������������������������������������������[0;32m[I][wifi:313]: WiFi Connecting to 'ChinaNet-5Yag'...[21:02:46][I][wifi:182]: Starting fallback AP![21:02:46][C][wifi:263]: Setting up AP...[21:02:46][C][wifi:265]:   AP SSID: 'X2 Fallback Hotspot'[21:02:46][C][wifi:266]:   AP Password: 'eVepP3vh9JTt'[21:02:47][W][wifi_esp32:545][arduino_events]: Event: Disconnected ssid='ChinaNet-5Yag' bssid=64:52:34:14:CA:50[redacted] reason='Auth Expired'[21:02:47][C][api:026]: Setting up Home Assistant API server...[21:02:47][I][app:062]: setup() finished successfully![21:02:47][W][wifi:653]: Error while connecting to network.[21:02:47][I][wifi:313]: WiFi Connecting to 'ChinaNet-5Yag'...[21:02:47][I][safe_mode:041]: Boot seems successful; resetting boot loop counter[21:02:47][D][esp32.preferences:114]: Saving 1 preferences to flash...[21:02:47][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed[21:02:47][W][component:157]: Component api set Warning flag: unspecified[21:02:47][I][app:100]: ESPHome version 2024.12.2 compiled on Feb  5 2025, 20:56:52[21:02:47][C][wifi:600]: WiFi:[21:02:48][C][wifi:428]:   Local MAC: 80:7D:3AF:36:30[21:02:48][C][wifi:433]:   SSID: 'ChinaNet-5Yag'[redacted][21:02:48][C][wifi:440]:   BSSID: 64:52:34:14:CA:50[redacted][21:02:48][C][wifi:441]:   Hostname: 'x2'[21:02:48][C][wifi:443]:   Signal strength: -66 dB ▂▄▆█[21:02:48][C][wifi:447]:   Channel: 1[21:02:48][C][wifi:448]:   Subnet: 0.0.0.0[21:02:48][C][wifi:449]:   Gateway: 0.0.0.0[21:02:48][C][wifi:450]:   DNS1: 0.0.0.0[21:02:48][C][wifi:451]:   DNS2: 0.0.0.0[21:02:48][C][logger:185]: Logger:[21:02:48][C][logger:186]:   Level: DEBUG[21:02:48][C][logger:188]:   Log Baud Rate: 115200[21:02:48][C][logger:189]:   Hardware UART: UART0[21:02:48][C][switch.gpio:068]: GPIO Switch 'Living Room'[21:02:48][C][switch.gpio:091]:   Restore Mode: always ON[21:02:48][C][switch.gpio:031]:   Pin: GPIO2[21:02:48][C][remote_receiver.esp32:064]: Remote Receiver:[21:02:48][C][remote_receiver.esp32:065]:   Pin: GPIO13[21:02:48][C][remote_receiver.esp32:070]:   Channel: 0[21:02:48][C][remote_receiver.esp32:071]:   RMT memory blocks: 3[21:02:48][C][remote_receiver.esp32:072]:   Clock divider: 80[21:02:48][C][remote_receiver.esp32:074]:   Tolerance: 25%[21:02:48][C][remote_receiver.esp32:075]:   Filter out pulses shorter than: 50 us[21:02:48][C][remote_receiver.esp32:076]:   Signal is done after 10000 us of no changes[21:02:48][C][captive_portal:089]: Captive Portal:[21:02:48][C][web_server:153]: Web Server:[21:02:48][C][web_server:154]:   Address: x2.local:80[21:02:48][C][mdns:116]: mDNS:[21:02:48][C][mdns:117]:   Hostname: x2[21:02:48][C][esphome.ota:073]: Over-The-Air updates:[21:02:48][C][esphome.ota:074]:   Address: x2.local:3232[21:02:48][C][esphome.ota:075]:   Version: 2[21:02:48][C][esphome.ota:078]:   Password configured[21:02:48][C][safe_mode:018]: Safe Mode:[21:02:48][C][safe_mode:020]:   Boot considered successful after 60 seconds[21:02:48][C][safe_mode:021]:   Invoke after 10 boot attempts[21:02:48][C][safe_mode:023]:   Remain in safe mode for 300 seconds[21:02:48][C][api:140]: API Server:[21:02:48][C][api:141]:   Address: x2.local:6053[21:02:48][C][api:143]:   Using noise encryption: YES[21:02:49][W][wifi_esp32:545][arduino_events]: Event: Disconnected ssid='ChinaNet-5Yag' bssid=64:52:34:14:CA:50[redacted] reason='Auth Expired'[21:02:49][W][wifi:653]: Error while connecting to network.[21:02:54][I][wifi:313]: WiFi Connecting to 'ChinaNet-5Yag'...[21:02:58][W][wifi_esp32:545][arduino_events]: Event: Disconnected ssid='ChinaNet-5Yag' bssid=64:52:34:14:CA:50[redacted] reason='Auth Expired'[21:02:58][W][wifi:653]: Error while connecting to network.[21:02:58][I][wifi:313]: WiFi Connecting to 'ChinaNet-5Yag'...[21:03:00][W][wifi_esp32:545][arduino_events]: Event: Disconnected ssid='ChinaNet-5Yag' bssid=64:52:34:14:CA:50[redacted] reason='Auth Expired'[21:03:00][W][wifi:653]: Error while connecting to network.[21:03:05][I][wifi:313]: WiFi Connecting to 'ChinaNet-5Yag'...[21:03:10][W][wifi_esp32:545][arduino_events]: Event: Disconnected ssid='ChinaNet-5Yag' bssid=64:52:34:14:CA:50[redacted] reason='Auth Expired'[21:03:10][W][wifi:653]: Error while connecting to network.[21:03:10][I][wifi:313]: WiFi Connecting to 'ChinaNet-5Yag'...[21:03:12][W][wifi_esp32:545][arduino_events]: Event: Disconnected ssid='ChinaNet-5Yag' bssid=64:52:34:14:CA:50[redacted] reason='Auth Expired'[21:03:12][W][wifi:653]: Error while connecting to network.[21:03:17][I][wifi:313]: WiFi Connecting to 'ChinaNet-5Yag'...[21:03:21][W][wifi_esp32:545][arduino_events]: Event: Disconnected ssid='ChinaNet-5Yag' bssid=64:52:34:14:CA:50[redacted] reason='Auth Expired'[21:03:21][W][wifi:653]: Error while connecting to network.[21:03:21][I][wifi:313]: WiFi Connecting to 'ChinaNet-5Yag'...[21:03:23][W][wifi_esp32:545][arduino_events]: Event: Disconnected ssid='ChinaNet-5Yag' bssid=64:52:34:14:CA:50[redacted] reason='Auth Expired'[21:03:23][W][wifi:653]: Error while connecting to network.
代码如下:
remote_receiver:
  pin:
    number: GPIO13
    inverted: True
    mode: INPUT_PULLUP
  dump: all
请高手指教一下!!!!!!!!!!!!!!!!!!!!!!!!!
发表于 2025-2-5 21:58:02 | 显示全部楼层
remote_receiver:
  pin:
    number: GPIO5
    inverted: true
    mode: INPUT_PULLUP
  dump: all
  idle: 80ms
remote_transmitter:
  pin: GPIO14
  carrier_duty_percent: 50%
会不会是引脚的问题
GMT+8, 2025-12-17 21:46 , Processed in 0.058360 second(s), 13 queries , MemCached On.
