查看: 6069|回复: 1
[技术探讨] openwrt-ubus的tracker
发表于 2018-2-24 14:14:25 | 显示全部楼层 |阅读模式
安装官方教程,最后显示这个错误,不知道该怎么调试了。。。可能是什么方面的问题?
2018-02-24 09:39:48 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform ubus
File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components/device_tracker/init.py", line 158, in async_setup_platform
platform.get_scanner, hass, {DOMAIN: p_config})
File "/usr/lib/python3.5/asyncio/futures.py", line 380, in iter
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
future.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components/device_tracker/ubus.py", line 42, in get_scanner
scanner = DnsmasqUbusDeviceScanner(config[DOMAIN])
File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components/device_tracker/ubus.py", line 141, in init
super(DnsmasqUbusDeviceScanner, self).init(config)
File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components/device_tracker/ubus.py", line 84, in init
self.password)
File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components/device_tracker/ubus.py", line 226, in _get_session_id
return res["ubus_rpc_session"]
TypeError: 'NoneType' object is not subscriptable
 楼主| 发表于 2018-3-5 09:11:03 | 显示全部楼层
搞不定啊搞不定。。。。。。
GMT+8, 2025-12-16 15:49 , Processed in 1.147360 second(s), 6 queries , MemCached On.
