之前安装的homeassistant可以正常使用,最近发现出现这个问题,请问有没有大佬知道是什么原因啊?
N2025-01-27T14:06:49.677881121Z s6-rc: info: service legacy-services: stopping
h2025-01-27T14:06:50.641201920Z [14:06:50] INFO: [32mHome Assistant Core finish process exit code 0[0m
^2025-01-27T14:06:50.642046801Z [14:06:50] INFO: [32mHome Assistant Core service shutdown[0m
Y2025-01-27T14:06:50.643872783Z s6-rc: info: service legacy-services successfully stopped
O2025-01-27T14:06:50.643936336Z s6-rc: info: service legacy-cont-init: stopping
Z2025-01-27T14:06:50.646437628Z s6-rc: info: service legacy-cont-init successfully stopped
H2025-01-27T14:06:50.646490565Z s6-rc: info: service fix-attrs: stopping
S2025-01-27T14:06:50.647119307Z s6-rc: info: service fix-attrs successfully stopped
R2025-01-27T14:06:50.647166073Z s6-rc: info: service s6rc-oneshot-runner: stopping
]2025-01-27T14:06:50.648194765Z s6-rc: info: service s6rc-oneshot-runner successfully stopped
R2025-01-27T14:06:55.915359021Z s6-rc: info: service s6rc-oneshot-runner: starting
]2025-01-27T14:06:55.917799928Z s6-rc: info: service s6rc-oneshot-runner successfully started
H2025-01-27T14:06:55.917852034Z s6-rc: info: service fix-attrs: starting
S2025-01-27T14:06:55.921614973Z s6-rc: info: service fix-attrs successfully started
O2025-01-27T14:06:55.921716190Z s6-rc: info: service legacy-cont-init: starting
Z2025-01-27T14:06:55.925164628Z s6-rc: info: service legacy-cont-init successfully started
N2025-01-27T14:06:55.925266062Z s6-rc: info: service legacy-services: starting
t2025-01-27T14:06:55.929612644Z services-up: info: copying legacy longrun home-assistant (no readiness notification)
Y2025-01-27T14:06:55.985717761Z s6-rc: info: service legacy-services successfully started
02025-01-27T14:06:56.426863070Z [33m2025-01-27 22:06:56.426 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant[0m
12025-01-27T14:06:56.427354523Z [33m2025-01-27 22:06:56.427 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration haier which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant[0m
/2025-01-27T14:06:56.427779279Z [33m2025-01-27 22:06:56.427 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration hon which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant[0m
82025-01-27T14:06:56.428201145Z [33m2025-01-27 22:06:56.427 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration midea_ac_lan which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant[0m
32025-01-27T14:06:56.428596125Z [33m2025-01-27 22:06:56.428 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration nodered which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant[0m
22025-01-27T14:06:56.429180969Z [33m2025-01-27 22:06:56.428 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration tianqi which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant[0m
22025-01-27T14:06:56.429673973Z [33m2025-01-27 22:06:56.429 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration webrtc which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant[0m
72025-01-27T14:06:56.430057048Z [33m2025-01-27 22:06:56.429 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration xiaomi_miot which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant[0m
2025-01-27T14:06:58.034366268Z [31m2025-01-27 22:06:58.033 ERROR (MainThread) [homeassistant.components.automation] Automation with alias '儿童房旋钮开关控制吸顶灯' failed to setup triggers and has been disabled: Unknown device '7894abde1f17b45e1a9157ec9e54146c'[0m
2025-01-27T14:06:58.036706408Z [31m2025-01-27 22:06:58.035 ERROR (MainThread) [homeassistant.components.automation] Automation with alias '厨房检测到水自动关闭阀门' failed to setup triggers and has been disabled: Unknown device 'c20e334cc90f054818b880049db9117c'[0m
