查看: 1190|回复: 2
[技术探讨] node-red的加载项总是错误以后自动恢复多次后就阳痿了停止了
发表于 2025-1-19 13:13:17 | 显示全部楼层 |阅读模式
19 Jan 13:07:34 - [red] Uncaught Exception:
19 Jan 13:07:34 - [error] UnhandledPromiseRejection: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason "3".
    at throwUnhandledRejectionsMode (node:internal/process/promises:392:7)
    at processPromiseRejections (node:internal/process/promises:475:17)
    at processTicksAndRejections (node:internal/process/task_queues:106:32)
总是会有这个错误,部署的时候。
而且好像这个错误重复的code都是一样都是392:7  475:17  106:32
多几次以后就自动停止掉整个nodered了
请赐教
 楼主| 发表于 2025-1-19 13:16:32 | 显示全部楼层
最后就这样了
Node-RED
The add-on is not running. Do you want to start it now?
问你要不要重启(必须手动去开启)
系统有自己的几次会自动重启,但是好像次数耗尽了就彻底关停node red
错误总是一样的错误就上面的内容
 楼主| 发表于 2025-1-20 16:02:24 | 显示全部楼层
有人可以告诉我这个错误是什么吗?去谷歌找了也有人反映过,最后不了了之
GMT+8, 2026-1-15 03:24 , Processed in 1.233885 second(s), 5 queries , MemCached On.
