查看: 1652|回复: 6
[求助] 2.0版本的z2m无法启动
发表于 2025-1-17 13:38:49 | 显示全部楼层 |阅读模式
升级前正常,升级2.0版本,无法启动Z2M,问了gpt也没给出具体的解决方法,各位帮忙看看啥问题
[13:15:32] INFO: Starting Zigbee2MQTT...
Starting Zigbee2MQTT without watchdog.
[2025-01-17 13:15:35] debug:         z2m: Removing old log directory '/config/zigbee2mqtt/log/2025-01-04.19-49-53'
[2025-01-17 13:15:35] info:         z2m: Logging to console, file (filename: log.log)
[2025-01-17 13:15:35] debug:         z2m: Loaded state from file /config/zigbee2mqtt/state.json
[2025-01-17 13:15:35] info:         z2m: Starting Zigbee2MQTT version 2.0.0 (commit #unknown)
[2025-01-17 13:15:35] debug:         z2m: sd-notify loaded
[2025-01-17 13:15:35] info:         z2m: Starting zigbee-herdsman (3.2.1)
[2025-01-17 13:15:35] debug:         z2m: Using zigbee-herdsman with settings: '"{"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":"HIDDEN"},"databasePath":"/config/zigbee2mqtt/database.db","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","backupPath":"/config/zigbee2mqtt/coordinator_backup.json","serialPort":{"path":"tcp://192.168.10.111:6638"},"adapter":{"disableLED":false}}"'
[2025-01-17 13:15:35] error:         z2m: Error while starting zigbee-herdsman
[2025-01-17 13:15:35] error:         z2m: Failed to start zigbee-herdsman
[2025-01-17 13:15:35] error:         z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-01-17 13:15:35] error:         z2m: Exiting...
[2025-01-17 13:15:35] error:         z2m: Error: Cannot discover TCP adapters at this time. Specify valid 'adapter' and 'port' in your configuration.
    at findTCPAdapter (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/adapterDiscovery.ts:470:15)
    at discoverAdapter (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/adapterDiscovery.ts:496:26)
    at Function.create (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/adapter.ts:68:54)
    at Controller.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/controller/controller.ts:132:38)
    at Zigbee.start (/app/lib/zigbee.ts:69:47)
    at Controller.start (/app/lib/controller.ts:142:13)
    at start (/app/index.js:161:5)
jjcs 手机认证
发表于 2025-1-17 14:02:08 | 显示全部楼层
z2m: Error: Cannot discover TCP adapters at this time. Specify valid 'adapter' and 'port' in your configuration.,问题很明确了。z2m版本大改,配置文件对协调器需要增加型号参数,具体去官网看
发表于 2025-1-17 21:36:32 | 显示全部楼层
配置里边最后要加一句话
发表于 2025-1-17 23:51:49 | 显示全部楼层
z2m配置文件更改成这个就可以启动了。
serial:
  adapter: zstack
 楼主| 发表于 2025-1-18 09:05:59 | 显示全部楼层
leilei 发表于 2025-1-17 23:51
z2m配置文件更改成这个就可以启动了。
serial:
  adapter: zstack
搞定
 楼主| 发表于 2025-1-18 21:19:13 | 显示全部楼层
z2m配置文件更改成这个就可以启动了。
serial:
  adapter: zstack
又有新问题啦,绿米的贴墙开关,在z2m里面有日志,但是mqtt里面没有action,只有电池电量,这个要咋弄
发表于 2025-1-18 21:35:15 | 显示全部楼层
kaka0992 发表于 2025-1-18 21:19
又有新问题啦,绿米的贴墙开关,在z2m里面有日志,但是mqtt里面没有action,只有电池电量,这个要咋弄 ...
Z2M里面改这个
homeassistant:
  legacy_action_sensor: true
参与人数 1金钱 +10 收起 理由
kaka0992 + 10 高手,这是高手!
GMT+8, 2025-12-18 21:12 , Processed in 0.345409 second(s), 12 queries , MemCached On.
