查看: 4463|回复: 27
[技术探讨] 请教如何在脚本动作中提取响应变量里某个值
发表于 2025-1-14 12:39:06 | 显示全部楼层 |阅读模式
最近的研究播放音乐,Music Assistant: 获取库项目动作,支持搜索具体的歌,在脚本里,配置好相关动作,勾选响应变量,他会返回json,1,我想提取items子项的长度,然后根据长度循环提取第一层级uri连接,
2,在脚本中如何临时保存这个uri链接的结果,因为我要在接下来的动作里执行播放媒体序列的操作
{"items":[{"media_type":"track","uri":"library://track/507","name":"你好,周杰伦","version":"","image":"http://172.*******","artists":[{"media_type":"artist","uri":"library://artist/343","name":"安又琪","version":"","image":null}],"album":{"media_type":"album","uri":"library://album/333","name":"Angela","version":"","image":"http://172.******}},{"media_type":"track","uri":"library://track/900","name":"01.夜的第七章","version":"","image":"http://172.*****","artists":[{"media_type":"artist","uri":"library://artist/36","name":"周杰伦","version":"","image":null}],"album":{"media_type":"album","uri":"library://album/126","name":"依然范特西","version":"","image":"http://172.*****"}}],"limit":1,"offset":0,"order_by":"name","media_type":"track"}
发表于 2025-1-14 14:34:42 | 显示全部楼层
变量啊。。。。。。。。。。
 楼主| 发表于 2025-1-14 14:39:09 | 显示全部楼层
隔壁的王叔叔 发表于 2025-1-14 14:34
变量啊。。。。。。。。。。
我不知道怎么弄,能不能简单的指导下,官方文档也没有写清楚
发表于 2025-1-14 14:44:08 | 显示全部楼层
看看这个能不能参考
alias: 给iphone发消息
sequence:
  - alias: Set up variables
    variables:
      action_confirm: "{{ 'CONFIRM_' ~ context.id }}"
      action_dismiss: "{{ 'DISMISS_' ~ context.id }}"
      notification_title: "{{ title }}"
      notification_message: "{{ message }}"
  - alias: Send notification
    domain: mobile_app
    type: notify
    device_id: bc3980f01c18ded90bea32c3eab17ef8
    title: "{{ notification_title }}"
    message: "{{ notification_message }}"
    data:
      actions:
        - action: "{{ action_confirm }}"
          title: 确认
        - action: "{{ action_dismiss }}"
          title: 忽略
  - alias: Awaiting response
    wait_for_trigger:
      - event_type: mobile_app_notification_action
        event_data:
        trigger: event
        event_data:
        trigger: event
  - choose:
      - conditions:
          - condition: template
            value_template: "{{ wait.trigger.event.data.action == action_confirm }}"
        sequence: []
      - conditions:
            value_template: "{{ wait.trigger.event.data.action == action_dismiss }}"
        sequence: []
description: ""
发表于 2025-1-14 14:51:00 | 显示全部楼层
用variables把值存起来
发表于 2025-1-14 14:56:24 | 显示全部楼层
我感觉你只能用模板了,就是在configuration.yaml里添加一个新的sensor:
template:
- sensor:
  - name: URI 列表
    unique_id: uri_list
    state: >
      {{ <这里是你的服务调用>.items | map(attribute='uri') | list | tojson }}
重启hass后
你可以在任何地方通过调用sensor.uri_list 来使用这个列表
每次服务调用更新了items时候,这个sensor会自动被更新
 楼主| 发表于 2025-1-14 15:01:57 | 显示全部楼层
template:
- sensor:
这里是你的服务调用,这个指的是,具体动作的名称吗
 楼主| 发表于 2025-1-14 15:02:18 | 显示全部楼层
好的,谢谢,我研究一下。
发表于 2025-1-14 15:06:31 | 显示全部楼层
不是动作名称,你那个json值是如何拿到的?
贴段代码来看看?不是所有的地方都支持variables
所以还是得先看你的代码
 楼主| 发表于 2025-1-14 15:15:03 | 显示全部楼层
所以还是得先 ...
我用这个代码{{ random_tracks.items}}获取,会报错,<built-in method items of dict object at 0x7fc1d9362ac0>,搜百度好像是items是py内置的方法,可是Music Assistant搜索返回的json里的名字是items,不知道怎么处理,{"items":[这里是歌曲的查询结果*****],"limit":1,"offset":0,"order_by":"name","media_type":"track"},我只是想拿到items子项长度,就是代表有几首歌,子项里的uri链接,就是歌曲的播放链接。
sequence:
  - data:
      media_type: track
      order_by: play_count
      config_entry_id: 01JGDGA7ZKA72W5VTN6YP6XG9D
      limit: 10
      search: 王力宏
    response_variable: random_tracks
    action: music_assistant.get_library
  - action: notify.persistent_notification
    data:
      message: "{{ random_tracks.items}}"
alias: 播放音乐模板
description: ""
GMT+8, 2026-1-15 00:30 , Processed in 1.620719 second(s), 4 queries , MemCached On.
