查看: 17064|回复: 9
[基础教程] 群晖Docker安装nginx 实现SSL 无法登录HASS
发表于 2018-2-21 23:35:27 | 显示全部楼层 |阅读模式
小白一枚,还是从论坛里找到了这个https://bbs.hassbian.com/forum.p ... =1686&highlight=ssl
说说经历吧:
方法1-HASS配置SSL,但homebridge连接不上SSL
方法2-docker 装nginx无法登录HASS
方法3-群晖自带的反向代理设置也是无法登录HASS
方法4-还是HASS配置SSL,
homebridge配置中增加 "verify_ssl":  false。就过了!
这次历时3天,花了3块钱开了腾讯和阿里的各一个域名,认识到了证书等相关知识。
多谢@
Jones 的提点,让群晖也顺带一起SSL了,这一步本来是在HASS后做的,结果经Jones的指点先整了~~
如题安装了NGINX 在/etc/nginx/conf.d/default.conf 中设置如下代码:
# HTTPS
server {
    listen 8122;
    server_name [url=http://www.d123ax.top]www.d123ax.top[/url];
    ssl on;
    #root html;
    #index index.html index.htm;
    ssl_certificate   /etc/nginx/conf.d/webssl/fullchain.pem;
    ssl_certificate_key  /etc/nginx/conf.d/webssl/privkey.key;
    ssl_session_timeout 5m;
    ssl_ciphers ECDHE-RSA-AES128-GCM-SHA256:ECDHE:ECDH:AES:HIGH:!NULL:!aNULL:!MD5:!ADH:!RC4;
    ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
    ssl_prefer_server_ciphers on;
    location / {
       proxy_pass  [url=http://127.0.0.1:8123;]http://127.0.0.1:8123;[/url]
                        #Proxy Settings
        proxy_redirect off;
        proxy_set_header Host $host:$server_port;
        proxy_set_header X-Real-IP $remote_addr;
        proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
        proxy_next_upstream error timeout invalid_header http_500 http_502 http_503 http_504;
        proxy_max_temp_file_size 0;
        proxy_connect_timeout 90;
        proxy_send_timeout 90;
        proxy_read_timeout 90;
        proxy_buffer_size 4k;
        proxy_buffers 4 32k;
        proxy_busy_buffers_size 64k;
        proxy_temp_file_write_size 64k;
返回的日志信息
/etc/nginx/nginx.conf 配置信息如下(未修改)
user  nginx;
worker_processes  1;
error_log  /var/log/nginx/error.log warn;
pid        /var/run/nginx.pid;
events {
    worker_connections  1024;
http {
    include       /etc/nginx/mime.types;
    default_type  application/octet-stream;
    log_format  main  '$remote_addr - $remote_user [$time_local] "$request" '
                      '$status $body_bytes_sent "$http_referer" '
                      '"$http_user_agent" "$http_x_forwarded_for"';
    access_log  /var/log/nginx/access.log  main;
    sendfile        on;
    #tcp_nopush     on;
    keepalive_timeout  65;
    #gzip  on;
    include /etc/nginx/conf.d/*.conf;
手机APP与网页均无法登录,长期转圈,求大神帮忙看看代码哪个有问题了~
发表于 2018-2-22 15:26:51 | 显示全部楼层
群晖本身就自带反向代理功能,控制面板里可以设置的。
发表于 2018-3-15 17:58:07 | 显示全部楼层
家里实现了群晖和docker HA的SSL,可提供远程支持。私信即可~
发表于 2018-3-16 09:01:23 | 显示全部楼层
搞什么私信的,把教程发论坛帮助更多人啊。。。
iLee
iLee
发表于 2018-3-16 09:07:12 | 显示全部楼层
我通过反向代理做ssl ha也是无法登陆。
群名叫iLee
GitHub叫ileez
Docker Hub叫zlee
这么多名字都是被逼的。。。
发表于 2018-3-16 13:20:57 | 显示全部楼层
https://bbs.hassbian.com/thread-3094-1-1.html
我是这样实现的
发表于 2018-7-12 11:25:02 | 显示全部楼层
发表于 2019-1-23 21:35:54 | 显示全部楼层
你好!请教 黑群辉已经实现了SSL访问 。docker里面 hass跟着群里教程试过都不行。直接就拒绝访问了。申请的是麻花藤的ssl
发表于 2019-1-24 12:51:17 | 显示全部楼层
hqboy 发表于 2019-1-23 21:35
你好!请教 黑群辉已经实现了SSL访问 。docker里面 hass跟着群里教程试过都不行。直接就拒绝访问了。申请 ...
可以帮你看看,定位故障
发表于 2022-9-4 15:12:10 | 显示全部楼层
我的群晖版本是6.2.4,设置反向代理后,SSL登录,提示400 Bad Request错误。。
GMT+8, 2026-1-18 13:51 , Processed in 0.144606 second(s), 11 queries , MemCached On.
