查看: 9131|回复: 2
关于小米空净的省电优化package
发表于 2018-2-21 23:36:51 | 显示全部楼层 |阅读模式
自从作为小白一名入坑以来,一直在论坛上学习,目前也初步有了一点小进步,基于Jones神的最新小米空气净化器2代接入HASS方法及HA控制面板(原帖地址:https://bbs.hassbian.com/thread-1657-1-1.html)。我在Jones神的基础上,改进了两点,也不知道对不对,发上来请大家批评。一是我个人觉得小米空净的led选择亮度意义不大,所以我改成了一个开关。二是我加了两个自动化,在AQI高于120的时候,空净自动打开为Auto模式,AQI低于80的时候,空净自动关闭,用来节电。三是把不用的自动化都给隐藏了。作为一名小白,从来不敢在论坛发帖子,也没发过帖子,不会上传附件,我直接把代码贴上来算了,排版不好,请大家批评。
  - platform: template
    sensors:
      xiaomi_ap_aqi:
        friendly_name: 空气质量
        value_template: "{{ states.fan.xiaomi_air_purifier_2.attributes.aqi }}"
        unit_of_measurement: AQI
      xiaomi_ap_temp:
        friendly_name: 温度
        value_template: "{{ states.fan.xiaomi_air_purifier_2.attributes.temperature }}"
        unit_of_measurement: °C
      xiaomi_ap_humid:
        friendly_name: 湿度
        value_template: "{{ states.fan.xiaomi_air_purifier_2.attributes.humidity }}"
        unit_of_measurement: "%"
switch:
    switches:
      xiaomi_ap_buzzer:
        value_template: "{{ is_state_attr('fan.xiaomi_air_purifier_2', 'buzzer', true) }}"
        turn_on:
          service: airpurifier.set_buzzer_on
          entity_id: fan.xiaomi_air_purifier_2
        turn_off:
          service: airpurifier.set_buzzer_off
      xiaomi_ap_led:
        value_template: "{{ is_state_attr('fan.xiaomi_air_purifier_2', 'led', true) }}"
        turn_on:
          service: fan.xiaomi_miio_set_led_on
        turn_off:
          service: fan.xiaomi_miio_set_led_off
input_select:
  xiaomi_ap_mode:
    icon: mdi:fan
    options:
      - "自动"
      - "睡眠"
      - "最爱"
      - "待机"
#   xiaomi_ap_led:
#     name: LED灯
#     icon: mdi:led-on
#     options:
#       - "亮光"
#       - "微光"
#       - "关闭"
group:
  xiaomi_air_purifier:
    view: no
    control: hidden
    entities:
      - fan.xiaomi_air_purifier_2
      - switch.xiaomi_ap_buzzer
      - switch.xiaomi_ap_led
      #- sensor.xiaomi_ap_aqi
      - sensor.xiaomi_ap_temp
      - sensor.xiaomi_ap_humid
      - sensor.xiaomi_ap_filter_used
      - sensor.xiaomi_ap_filter_life
      - input_select.xiaomi_ap_mode
#       - input_select.xiaomi_ap_led
automation:
  - alias: xiaomi_ap_get_mode
    initial_state: true
    trigger:
      platform: time
      seconds: /5
    action:
      service: input_select.select_option
      data_template:
        entity_id: input_select.xiaomi_ap_mode
        option: >
          {% if states.fan.xiaomi_air_purifier_2.attributes.mode == "auto" %}自动
          {% elif states.fan.xiaomi_air_purifier_2.attributes.mode == "silent" %}睡眠
          {% elif states.fan.xiaomi_air_purifier_2.attributes.mode == "favorite" %}最爱
          {% elif states.fan.xiaomi_air_purifier_2.attributes.mode == "idle" %}待机
          {% endif %}
  - alias: xiaomi_ap_set_mode
    initial_state: true
    trigger:
      platform: state
    action:
      service: fan.turn_on
      data_template:
        speed: >
          {% if states.input_select.xiaomi_ap_mode.state == "自动" %}Auto
          {% elif states.input_select.xiaomi_ap_mode.state == "睡眠" %}Silent
          {% elif states.input_select.xiaomi_ap_mode.state == "最爱" %}Favorite
          {% elif states.input_select.xiaomi_ap_mode.state == "待机" %}Idle
          {% endif %}
  - alias: xiaomiap_aotu_turnon #api高于120自动启动,速度定位aoto
    initial_state: true
    trigger:
      platform: numeric_state
      value_template: '{{ state.attributes.aqi }}'
      above: 120
    condition:
      - condition: state
        state: 'off'
    action:
      data_template:
        speed: Auto
  - alias: xiaomiap_aotu_turnoff #api低于80自动关闭,节约用电
    initial_state: true
    trigger:
      below: 80
    condition:
      - condition: state
        state: 'on'
    action:
      service: fan.turn_off
      data_template:
#   - alias: xiaomi_ap_get_led
#     initial_state: true
#     trigger:
#       platform: time
#       seconds: /5
#     action:
#       service: input_select.select_option
#       data_template:
#         entity_id: input_select.xiaomi_ap_led
#         option: >
#          {% if states.fan.xiaomi_air_purifier_2.attributes.led_brightness == 0 %}亮光
#          {% elif states.fan.xiaomi_air_purifier_2.attributes.led_brightness == 1 %}微光
#          {% elif states.fan.xiaomi_air_purifier_2.attributes.led_brightness == 2 %}关闭
#          {% endif %}
#   - alias: xiaomi_ap_set_led
#     trigger:
#     action:
#       service: airpurifier.set_led_brightness
#       data_template:
#         entity_id: fan.xiaomi_air_purifier_2
#         brightness: >
#          {% if states.input_select.xiaomi_ap_led.state == "亮光" %}0
#          {% elif states.input_select.xiaomi_ap_led.state == "微光" %}1
#          {% elif states.input_select.xiaomi_ap_led.state == "关闭" %}2
#          {% endif %}
homeassistant:
  customize:
    fan.xiaomi_air_purifier_2:
      friendly_name: 空净开关
      homebridge_name: 空净开关
      homebridge_visible: true
      extra_badge:
        entity_id: sensor.xiaomi_ap_aqi
      extra_data_template: 滤芯已用${attributes.filter_hours_used}小时,剩余${attributes.filter_life_remaining}%
    switch.xiaomi_ap_buzzer:
      icon: mdi:volume-high
      friendly_name: 提示音
    switch.xiaomi_ap_led:
      icon: mdi:led-on
      friendly_name: 指示灯
    sensor.xiaomi_ap_aqi:
      icon: mdi:blur
      homebridge_name: 客厅空气质量
    sensor.xiaomi_ap_humid:
      friendly_name: 客厅湿度
      icon: mdi:water-percent
      homebridge_name: 客厅湿度
    sensor.xiaomi_ap_temp:
      friendly_name: 客厅温度
      homebridge_name: 客厅温度
    automation.xiaomi_ap_get_mode:
      hidden: true
    automation.xiaomi_ap_set_mode:
      hidden: true
    automation.xiaomiap_aotu_turnon:
      hidden: true
    automation.xiaomiap_aotu_turnoff:
      hidden: true
参与人数 2金钱 +19 收起 理由
killadm + 7 谢谢分享!
+ 12 谢谢分享!
发表于 2018-2-22 00:02:42 | 显示全部楼层
非常好!楼主太谦虚了!
发表于 2018-7-13 19:27:38 | 显示全部楼层
这个自动化的思路很值得借鉴,已经实施!
GMT+8, 2026-1-3 07:00 , Processed in 1.366881 second(s), 8 queries , MemCached On.
