查看: 1360|回复: 4
[求助] 旋转编码器调整色温
发表于 2025-1-9 14:18:09 | 显示全部楼层 |阅读模式
我想用旋转编码器+8266+esphome通过api做一个无线调整灯光亮度和色温的测试,现在出现了一个问题:
1、现有代码可以实现顺时针旋转编码器增加亮度,逆时针旋转编码器调暗灯光
2、长按通过color_temp_kelvin只会增加开尔文的数值,当达到灯的最大值后,不会循环减小,而且8266会掉线。
3、如果在esphome中建立一个灯,那么代码使用没问题
可以帮忙看看代码哪地方有问题吗,谢谢!
#旋转调整亮度
  - platform: rotary_encoder
    pin_a:
      number: RX
      inverted: True
      mode:
         input: true
         pullup: true
    pin_b:
      number: TX
      inverted: True
      mode:
         input: true
         pullup: true
    resolution: 2
    min_value: 0
    max_value: 30
    publish_initial_value: true
    on_clockwise:
      - homeassistant.service:
          service: light.turn_on
          data:
            entity_id:
               light.color_taideng_2024
            brightness_step_pct: "5"
            transition: "0.1"
      - delay: 0.1s
    on_anticlockwise:
          data:
            entity_id:
            brightness_step_pct: "-5"
            transition: "0.1"
      - delay: 0.1s
#长按调调颜色,单击开关灯
globals:
 - id: my_global_inta
   type: int
   restore_value: no
   initial_value: '2000'
binary_sensor:
  - platform: gpio
    pin:
      number: 5
      inverted: True
      mode:
        input: True
        pullup: True
    internal: true
    on_press:
      then:
       - while:
           condition:
            - binary_sensor.is_on: my_binary_sensor
           then:
           - while:
               condition:
                - lambda: |-
                            return (id(my_global_inta) >= 2000) && (id(my_global_inta) < 6536);
               then:
                    data:
                      entity_id: light.color_taideng_2024
                      transition: "0.1"
                      color_temp_kelvin: !lambda |-
                          id(my_global_inta) += 20;
                          return id(my_global_inta);
                - delay: 0.1s
           - while:
               condition:
                - lambda: |-
                            return (id(my_global_inta) > 2000) && (id(my_global_inta) <= 6536);
               then:
                    data:
                      transition: "0.1"
                          id(my_global_inta) -= 4000;
                - delay: 0.1s
    on_click:
      then:
                    service: light.toggle
                    data:
                - delay: 0.05s
 楼主| 发表于 2025-1-9 14:19:33 | 显示全部楼层
补充一下,我的灯色温范围是2000k-6536k
发表于 2025-1-9 18:38:49 | 显示全部楼层
不会循环的原因是没写循环逻辑,重启的原因是陷入死循环导致看门狗超时
 楼主| 发表于 2025-1-10 08:57:33 | 显示全部楼层
谢谢,我试试
 楼主| 发表于 2025-1-10 14:38:51 | 显示全部楼层
检查到了,第二个内循环的条件错了,旋转编码器的值不一定是6536,或许超过了,不一定是20的整倍数,所以不能循环。
GMT+8, 2025-12-15 23:58 , Processed in 0.388607 second(s), 8 queries , MemCached On.
