查看: 2907|回复: 6
[技术探讨] 奥克斯空调极速侠成功接入haos
发表于 2025-1-6 17:55:52 | 显示全部楼层 |阅读模式
家里有两台极速侠,空调原先是支持阿里智能的,后来奥克斯与阿里不合作了,同时在这个时候接触了haos,想着所有设备都能接入到一个系统,于是打电话给售后,让换了一个新模块,能接入奥克斯自己的a+ app,网上找了好多资料,都不支持,包括broadlinkac2mqtt.
也通过论坛知道了俄国大神的 https://github.com/GrKoR/esphome_aux_ac_component 帖子,
由于设备不一样,加上自己是新手,疯狂找资料,结果还真成了.
模块背面
模块背面
模块正面
模块正面
这是我空调的模块,他同时负责遥控和显示屏的功能,这与大神的设备不一样,
668240826e9f9162f6f0a3062a52a20.jpg 通信模块的型号是BL3389-P又经过一番寻找,找到了这个通讯模块的资料
用户手册.pdf (648.26 KB, 下载次数: 15)
bf43d24f5983df5b60d424b1398bf02.jpg 于是开始拆吧
烙铁不太会用,就用刀片一点点扣下来,
d1接主板的左4
d2接主板的左5
由于主板有5v电源
5v电源和gnd接到主板的电源上
下面就是esphome的代码了,这是参考俄国大神的。
esphome:
  friendly_name: aux-ac-01
esp8266:
  board: d1_mini
# Enable logging
logger:
    level: DEBUG
    hardware_uart: UART1
# Enable Home Assistant API
api:
  encryption:
    key: "111111"
ota:
  password: "111111"
wifi:
  ssid: "111111"
  password: "111111"
  ap:
    ssid: "Aux-Ac-01 Fallback Hotspot"
    password: "111111"
captive_portal:
external_components:
  - source:
      type: git
      url: https://github.com/GrKoR/esphome_aux_ac_component
uart:
  tx_pin: GPIO5
  rx_pin: GPIO4
  baud_rate: 4800
  data_bits: 8
  parity: EVEN
  stop_bits: 1
light:
  - platform: status_led
    pin:
      number: GPIO2 # 关闭了esp的led灯,影响睡觉
      inverted: true
    restore_mode: ALWAYS_OFF
climate:
  - platform: aux_ac
    uart_id: ac_uart_bus
    period: 7s
    show_action: true
    display_inverted: false
    timeout: 150
    optimistic: true
    indoor_temperature:
      name: AC Indoor Temperature
      internal: false
    display_state:
      name: AC Display State
      internal: false
    outdoor_temperature:
      name: AC Outdoor Temperature
      internal: false
    outbound_temperature:
      name: AC Coolant Outbound Temperature
      internal: false
    inbound_temperature:
      name: AC Coolant Inbound Temperature
      internal: false
    compressor_temperature:
      name: AC Compressor Temperature
      internal: false
    defrost_state:
      name: AC Defrost State
      internal: false
    inverter_power:
      name: AC Invertor Power
      internal: false
    preset_reporter:
      name: AC Preset Reporter
      internal: false
    vlouver_state:
      name: AC VLouvers State
      internal: false
    visual:
      min_temperature: 16
      max_temperature: 32
      temperature_step: 0.5
    supported_modes:
      - HEAT_COOL
      - COOL
      - HEAT
      - DRY
      - FAN_ONLY
    custom_fan_modes:
      - MUTE
      - TURBO
    supported_presets:
      - SLEEP
    custom_presets:
      - CLEAN
      - HEALTH
      - ANTIFUNGUS
    supported_swing_modes:
      - VERTICAL
      - HORIZONTAL
      - BOTH
  # just wifi signal strength for debug purpose only
  - platform: wifi_signal
    name: AC WiFi Signal
    update_interval: 30s
    unit_of_measurement: "dBa"
    accuracy_decimals: 0
  - platform: uptime
    name: AC Uptime Sensor
switch:
  - platform: template
    lambda: |-
      if (id(ac_display_state).state) {
        return true;
      } else {
        return false;
    turn_on_action:
      - aux_ac.display_on: aux_id
    turn_off_action:
      - aux_ac.display_off: aux_id
button:
    name: AC VLouver Stop
    icon: "mdi:circle-small"
    on_press:
      - aux_ac.vlouver_stop: aux_id
    name: AC VLouver Swing
    icon: "mdi:pan-vertical"
    on_press:
      - aux_ac.vlouver_swing: aux_id
    name: AC VLouver Top
    icon: "mdi:pan-up"
    on_press:
      - aux_ac.vlouver_top: aux_id
    name: AC VLouver Middle Above
    icon: "mdi:pan-top-left"
    on_press:
      - aux_ac.vlouver_middle_above: aux_id
    icon: "mdi:pan-left"
    on_press:
      - aux_ac.vlouver_middle: aux_id
    name: AC VLouver Middle Below
    icon: "mdi:pan-bottom-left"
    on_press:
      - aux_ac.vlouver_middle_below: aux_id
    name: AC VLouver Bottom
    icon: "mdi:pan-down"
    on_press:
      - aux_ac.vlouver_bottom: aux_id
number:
    name: AC Vertical Louvers
    mode: "slider"
    min_value: 0
    max_value: 6
    step: 1
    update_interval: 2s
    lambda: |-
      return id(ac_vlouver_state).state;
    set_action:
      then:
        - aux_ac.vlouver_set:
            position: !lambda "return x;"
    name: AC Power Limit
    icon: "mdi:battery-unknown"
    mode: "slider"
    min_value: 30
    max_value: 100
    step: 1
    set_action:
      then:
        - lambda: !lambda "id(aux_id).powerLimitationOnSequence( x );"
发表于 2025-1-6 19:19:10 | 显示全部楼层
楼主,是原板子上的芯片不用拆掉,只要增加esp8266 d1 mini板子按示意图上(d1接主板的右4,,d2接主板的右5,,5v电源和gnd接到主板的电源上)接上就可以吗??????谢谢!!!!
发表于 2025-1-6 19:51:01 | 显示全部楼层
看上了楼主的空调卡片
 楼主| 发表于 2025-1-6 21:47:40 | 显示全部楼层
fiyenui 发表于 2025-1-6 19:19
楼主,是原板子上的芯片不用拆掉,只要增加esp8266 d1 mini板子按示意图上(d1接主板的右4,,d2接主板的右 ...
我的是拆掉了的,怕以后有什么莫名其妙的问题,怕会串流,图片是为了看的更清楚,所以用的是芯片还在的时候的样子
 楼主| 发表于 2025-1-6 21:49:13 | 显示全部楼层
jjss520 发表于 2025-1-6 19:51
看上了楼主的空调卡片
卡片是Bubble Card
2011 手机认证
发表于 2025-1-11 02:18:33 | 显示全部楼层
好厉害!!!问一下楼主,你怎么知道用博联芯片的4、5脚连接8266的?
 楼主| 发表于 2025-1-13 08:24:16 | 显示全部楼层
找了下他的  用户手册.pdf 看在根据实际分析,他的rx和tx是没有和主板连接的.
GMT+8, 2026-1-15 02:02 , Processed in 0.149015 second(s), 13 queries , MemCached On.
