查看: 4116|回复: 11
[插件集成] xiaomi 突然没有设备了
发表于 2025-1-2 19:52:57 | 显示全部楼层 |阅读模式
下午突然所有的实体都不可用了,
miot auto 找不到设备
xiaom home 也找不到设备
可用米家app 里面好好地啊
发表于 2025-1-2 19:58:44 | 显示全部楼层
今晚刚更新到最新版,没有问题呀
 楼主| 发表于 2025-1-2 20:01:50 | 显示全部楼层
更新到1.0.8也不行 重新配置说我账号下没有设备。。。。
发表于 2025-1-2 20:18:50 | 显示全部楼层
什么情况了
 楼主| 发表于 2025-1-2 21:17:14 | 显示全部楼层
Device model / 设备型号
all
Component version / 插件版本
1.0.8
HA core version / HA版本
2024.11.3
Integrated mode / 集成方式
Automatic (自动模式)
The problem / 问题详情
Core
2024.11.3
Frontend
20241106.2
Xiaomi Miot Auto:1.0.8
该小米账户下没有设备
4.png 4
Entity attributes / 实体属性
无实体
Home Assistant Logs / 系统日志
此错误来自自定义集成。
日志记录器: custom_components.xiaomi_miot-2.sensor
来源: custom_components/xiaomi_miot-2/sensor.py:765
集成: xiaomi_miot-2
首次出现: 20:56:40 (2 次总计出现)
上次记录: 20:58:45
Get xiaomi scene history for 221xxx98 437xxxx825 failed: {'code': 0, 'message': 'SERVICETOKEN_EXPIRED'}
此错误来自自定义集成。
来源: custom_components/xiaomi_miot-2/sensor.py:647
集成: xiaomi_miot-2
上次记录: 20:58:45
Get xiaomi message for 22xxxxx98 failed: {'code': 0, 'message': 'SERVICETOKEN_EXPIRED'}
此错误来自自定义集成。
来源: custom_components/xiaomi_miot-2/init.py:300
集成: xiaomi_miot-2
首次出现: 20:56:39 (2 次总计出现)
上次记录: 20:58:45
None device in xiaomi cloud: 18xxxxx1
日志记录器: homeassistant.const
来源: helpers/deprecation.py:222
首次出现: 20:56:21 (16 次总计出现)
上次记录: 20:56:40
STATE_ALARM_ARMED_AWAY was used from xiaomi_miot-2, this is a deprecated constant which will be removed in HA Core 2025.11. Use AlarmControlPanelState.ARMED_AWAY instead, please report it to the author of the 'xiaomi_miot-2' custom integration
STATE_ALARM_ARMED_HOME was used from xiaomi_miot-2, this is a deprecated constant which will be removed in HA Core 2025.11. Use AlarmControlPanelState.ARMED_HOME instead, please report it to the author of the 'xiaomi_miot-2' custom integration
STATE_ALARM_ARMED_NIGHT was used from xiaomi_miot-2, this is a deprecated constant which will be removed in HA Core 2025.11. Use AlarmControlPanelState.ARMED_NIGHT instead, please report it to the author of the 'xiaomi_miot-2' custom integration
STATE_ALARM_DISARMED was used from xiaomi_miot-2, this is a deprecated constant which will be removed in HA Core 2025.11. Use AlarmControlPanelState.DISARMED instead, please report it to the author of the 'xiaomi_miot-2' custom integration
STATE_ALARM_TRIGGERED was used from xiaomi_miot-2, this is a deprecated constant which will be removed in HA Core 2025.11. Use AlarmControlPanelState.TRIGGERED instead, please report it to the author of the 'xiaomi_miot-2' cu
发表于 2025-1-3 08:25:42 | 显示全部楼层
昨晚刚更新,没问题啊
发表于 2025-1-3 14:27:52 | 显示全部楼层
ha的版本不能太高,太高了,不能用,我降级了
发表于 2025-1-3 14:36:39 | 显示全部楼层
core版本升级到12.5,要不然miot auto降级
发表于 2025-1-9 13:50:33 | 显示全部楼层
我这定时重启完 MIOT里也“None device in xiaomi cloud”了
系统没升级,MIOT也没升级,为何会出现这问题?
备份完升级下 core看看。
发表于 2025-1-9 16:19:30 | 显示全部楼层
系统没升级,MIOT也没升级,为何会出现这问题 ...
hass-xiaomi-miot 更新到 0.7.22后,正常了。 我升级前是0.7.19
参考
https://github.com/al-one/hass-xiaomi-miot/issues/1907
GMT+8, 2025-11-30 08:14 , Processed in 1.425542 second(s), 14 queries , MemCached On.
