查看: 1352|回复: 4
[技术探讨] 求助,始终无法安装frigate card
发表于 2024-12-31 13:39:13 | 显示全部楼层 |阅读模式
群晖,docker安装了最新版的Homeassistant和hacs,但是在hacs可以搜索到frigate card,也是正常获取到版本,但是download点了就是下载下来!,一直在长跑
发表于 2024-12-31 13:46:40 | 显示全部楼层
安装hacs极速版,639102727群里有
 楼主| 发表于 2024-12-31 13:49:18 | 显示全部楼层
后台日志,提示超时
2024-12-31 13:48:09.190 WARNING (MainThread) [custom_components.hacs] A timeout of 60! seconds was encountered while downloading https://raw.githubusercontent.com/dermotduffy/frigate-hass-card/v6.1.2/README.md, using over 60 seconds to download a single file is not normal. This is not a problem with HACS but how your host communicates with GitHub. Retrying up to 5 times to mask/hide your host/network problems to stop the flow of issues opened about it. Tries left 4
2024-12-31 13:48:15.488 ERROR (45f468edfc2c6caa) [custom_components.xiaomi_home.miot.miot_client] 1037991129家, mips try reconnect after 60000ms
2024-12-31 13:48:16.191 WARNING (MainThread) [custom_components.hacs] A timeout of 60! seconds was encountered while downloading https://github.com/dermotduffy/frigate-hass-card/releases/download/v6.1.2/date-picker-d9927b87.js, using over 60 seconds to download a single file is not normal. This is not a problem with HACS but how your host communicates with GitHub. Retrying up to 5 times to mask/hide your host/network problems to stop the flow of issues opened about it. Tries left 4
2024-12-31 13:48:16.191 WARNING (MainThread) [custom_components.hacs] A timeout of 60! seconds was encountered while downloading https://github.com/dermotduffy/frigate-hass-card/releases/download/v6.1.2/card-e5d55e5b.js, using over 60 seconds to download a single file is not normal. This is not a problem with HACS but how your host communicates with GitHub. Retrying up to 5 times to mask/hide your host/network problems to stop the flow of issues opened about it. Tries left 4
2024-12-31 13:48:16.191 WARNING (MainThread) [custom_components.hacs] A timeout of 60! seconds was encountered while downloading https://github.com/dermotduffy/frigate-hass-card/releases/download/v6.1.2/engine-86b0096c.js, using over 60 seconds to download a single file is not normal. This is not a problem with HACS but how your host communicates with GitHub. Retrying up to 5 times to mask/hide your host/network problems to stop the flow of issues opened about it. Tries left 4
2024-12-31 13:48:16.192 WARNING (MainThread) [custom_components.hacs] A timeout of 60! seconds was encountered while downloading https://github.com/dermotduffy/frigate-hass-card/releases/download/v6.1.2/endpoint-c9cec68c.js, using over 60 seconds to download a single file is not normal. This is not a problem with HACS but how your host communicates with GitHub. Retrying up to 5 times to mask/hide your host/network problems to stop the flow of issues opened about it. Tries left 4
2024-12-31 13:48:16.192 WARNING (MainThread) [custom_components.hacs] A timeout of 60! seconds was encountered while downloading https://github.com/dermotduffy/frigate-hass-card/releases/download/v6.1.2/endOfDay-cfc9c86c.js, using over 60 seconds to download a single file is not normal. This is not a problem with HACS but how your host communicates with GitHub. Retrying up to 5 times to mask/hide your host/network problems to stop the flow of issues opened about it. Tries left 4
2024-12-31 13:48:16.192 WARNING (MainThread) [custom_components.hacs] A timeout of 60! seconds was encountered while downloading https://github.com/dermotduffy/frigate-hass-card/releases/download/v6.1.2/audio-cf3a75aa.js, using over 60 seconds to download a single file is not normal. This is not a problem with HACS but how your host communicates with GitHub. Retrying up to 5 times to mask/hide your host/network problems to stop the flow of issues opened about it. Tries left 4
2024-12-31 13:48:16.192 WARNING (MainThread) [custom_components.hacs] A timeout of 60! seconds was encountered while downloading https://github.com/dermotduffy/frigate-hass-card/releases/download/v6.1.2/editor-238b96c0.js, using over 60 seconds to download a single file is not normal. This is not a problem with HACS but how your host communicates with GitHub. Retrying up to 5 times to mask/hide your host/network problems to stop the flow of issues opened about it. Tries left 4
2024-12-31 13:48:16.193 WARNING (MainThread) [custom_components.hacs] A timeout of 60! seconds was encountered while downloading https://github.com/dermotduffy/frigate-hass-card/releases/download/v6.1.2/engine-generic-93cdbee6.js, using over 60 seconds to download a single file is not normal. This is not a problem with HACS but how your host communicates with GitHub. Retrying up to 5 times to mask/hide your host/network problems to stop the flow of issues opened about it. Tries left 4
2024-12-31 13:48:16.193 WARNING (MainThread) [custom_components.hacs] A timeout of 60! seconds was encountered while downloading https://github.com/dermotduffy/frigate-hass-card/releases/download/v6.1.2/engine-frigate-be325e58.js, using over 60 seconds to download a single file is not normal. This is not a problem with HACS but how your host communicates with GitHub. Retrying up to 5 times to mask/hide your host/network problems to stop the flow of issues opened about it. Tries left 4
2024-12-31 13:48:16.193 WARNING (MainThread) [custom_components.hacs] A timeout of 60! seconds was encountered while downloading https://github.com/dermotduffy/frigate-hass-card/releases/download/v6.1.2/engine-motioneye-aba6e54b.js, using over 60 seconds to download a single file is not normal. This is not a problem with HACS but how your host communicates with GitHub. Retrying up to 5 times to mask/hide your host/network problems to stop the flow of issues opened about it. Tries left 4
 楼主| 发表于 2024-12-31 13:57:50 | 显示全部楼层
B站用户名……
发表于 2024-12-31 14:28:18 | 显示全部楼层
hacs-china啊,along大佬的
GMT+8, 2026-1-14 21:12 , Processed in 0.263709 second(s), 9 queries , MemCached On.
