查看: 1721|回复: 4
[技术探讨] 旋转编码器长按没反应?
发表于 2024-12-30 13:15:24 | 显示全部楼层 |阅读模式
通过8266-01s+旋转编码器做了一个直流调光,想达到长按旋转编码器进行等颜色切换,这个怎么
output:
  - platform: esp8266_pwm
    pin: RX    #D4
    frequency: 3000 Hz
    min_power: 0.05
    max_power: 0.99
    zero_means_zero: true
#    power_supply: power
light:
  - platform: monochromatic
    output: pwm_output
    default_transition_length: 5s
  - platform: rotary_encoder
    pin_a:
      number: 2
      inverted: True
      mode:
         input: true
         pullup: true
    pin_b:
      number: TX
      inverted: True
      mode:
         input: true
         pullup: true
    resolution: 2
    min_value: 0
    max_value: 30
    publish_initial_value: true
    on_clockwise:
    - light.dim_relative:
        relative_brightness: 5%
        transition_length: 0.1s
        brightness_limits:
            max_brightness: 100%
    - delay: 0.1s
    on_anticlockwise:
        relative_brightness: -5%
        brightness_limits:
            min_brightness: 10%
    - delay: 0.1s
#增加一个通断火线的电源开关
#power_supply:
#  - id: power
#    pin:
#      number: GPIO0
#      inverted: True
#    keep_on_time: 10ms
#按压旋转编码器开关灯,双击切换颜色,长按不知道怎么搞
binary_sensor:
  - platform: gpio
    pin: 0
#长按进行灯光颜色切换
#    on_multi_click:
#    - timing:
#       - ON for 1s to 3s
#       - OFF for at least 0.1s
    on_double_click:
      min_length: 50ms
      max_length: 350ms
      then:
        - light.turn_on:
            brightness: 100%
            red: 100%
            green: 100%
            blue: 1.0
    on_press:
       then:
         - light.toggle:
实现呢?麻烦大佬帮忙看看,谢谢啦!
 楼主| 发表于 2024-12-30 13:18:50 | 显示全部楼层
没有多色灯带,暂时用的单色灯来测试的
light:
    output: pwm_output
发表于 2024-12-30 20:34:57 | 显示全部楼层
代码里面没看到你关于长按的设置啊
 楼主| 发表于 2024-12-31 10:05:31 | 显示全部楼层
我注释掉了,编译不了book123
 楼主| 发表于 2025-1-6 17:48:58 | 显示全部楼层
已经解决了,谢谢!
#先增加一个pwm控制器
output:
    pin: GPIO12
    frequency: 3000 Hz
    power_supply: power
    pin: GPIO13
    frequency: 3000 Hz
    power_supply: power
light:
#冷暖灯
 - platform: cwww
   cold_white: pwm_output_col
   warm_white: pwm_output_bri
   icon: "mdi:lightbulb-on-outline"
   cold_white_color_temperature: 6536 K
   warm_white_color_temperature: 2000 K
   constant_brightness: true
#长按调调颜色,单击开关灯
globals:
 - id: my_global_int
   type: float
   restore_value: no
   initial_value: '0'
 - id: my_global_inta
   type: double
   restore_value: no
   initial_value: '150'
 - id: my_global_intc
   type: float
   restore_value: no
   initial_value: '2'
binary_sensor:
  - platform: gpio
    pin:
      number: 5
      inverted: True
      mode: INPUT_PULLUP
    internal: true
    on_press:
      then:
       - while:
           condition:
            - binary_sensor.is_on: my_binary_sensor
           then:
           - while:
               condition:
                - lambda: |-
                            return (id(my_global_inta) >= 150) && (id(my_global_inta) < 500);
               then:
               - light.turn_on:
                  color_temperature: !lambda |-
                          id(my_global_inta) += 5;
                          return id(my_global_inta);
               - delay: 0.1s
           - while:
               condition:
                - lambda: |-
                            return (id(my_global_inta) > 150) && (id(my_global_inta) <= 500);
               then:
               - light.turn_on:
                          id(my_global_inta) -= 5;
               - delay: 0.1s
    on_click:
      then:
        light.toggle: dimmer
#旋转调整亮度
#    pin_a: 2
    pin_a:
      number: RX
      inverted: True
      mode:
         input: true
         pullup: true
#    pin_b: TX
    pin_b:
      number: TX
      inverted: True
      mode:
         input: true
         pullup: true
    resolution: 2
    min_value: 0
    max_value: 30
    on_clockwise:
        brightness_limits:
    - delay: 0.1s
    on_anticlockwise:
        brightness_limits:
            min_brightness: 10%
    - delay: 0.1s
#增加一个通断继电器的电源开关
power_supply:
  - id: power
    pin:
      number: GPIO4
      inverted: False
    keep_on_time: 10ms
想问问,如果用8266+旋转编码器做成无线控制的,不知道可以实现不?esphome 调用homeassistant中的灯好像不行,只有switch,郁闷!
GMT+8, 2026-1-14 22:52 , Processed in 0.612389 second(s), 7 queries , MemCached On.
