查看: 8977|回复: 3
HOMEBridge无法加载设备
发表于 2018-2-14 21:56:15 | 显示全部楼层 |阅读模式
Home Assistant已经认出小米二代的网关
但是HOME Bridge加载数量为0。。。
应该不用配置其他的地方能自动带出了吧
Server startup complete. Host name is hassio.local. Local service cookie is 21579210.
*** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see [url]http://0pointer.de/avahi-compat?s=libdns_sd&e=node[/url]
*** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** For more information see [url]http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister[/url]
[2018-2-13 23:37:18] Loaded plugin: homebridge-homeassistant
[2018-2-13 23:37:19] Registering platform 'homebridge-homeassistant.HomeAssistant'
[2018-2-13 23:37:19] ---
[2018-2-13 23:37:19] Loaded config.json with 0 accessories and 1 platforms.
[2018-2-13 23:37:19] Loading 1 platforms...
[2018-2-13 23:37:19] [HomeAssistant] Initializing HomeAssistant platform...
[2018-2-13 23:37:19] [HomeAssistant] Fetching HomeAssistant devices.
[2018-2-13 23:37:19] Loading 0 accessories...
[2018-2-13 23:37:19] [HomeAssistant] Received event: ping
hugo
发表于 2018-2-15 17:48:50 | 显示全部楼层
看上去没问题
 楼主| 发表于 2018-2-16 18:52:05 | 显示全部楼层
最后查出来是配置的可见设为隐藏了。。。
发表于 2018-2-25 21:29:07 | 显示全部楼层
隐藏怎么修改为颗见
GMT+8, 2026-1-7 06:39 , Processed in 0.147684 second(s), 11 queries , MemCached On.
