查看: 1491|回复: 5
[求助] 小白求助刷入esp32都会出现无法开机是什么原因
发表于 2024-12-22 22:04:01 | 显示全部楼层 |阅读模式
没配置yaml也不行,刷进去就一直重复消息:
求大佬带带我。呜呜呜。开发板换了三个测试都一样,arduino刷入运行都正常。就是esphome刷入就一直死循环
发表于 2024-12-22 23:11:54 | 显示全部楼层
用ESPHome-Flasher刷入试试
 楼主| 发表于 2024-12-22 23:30:45 | 显示全部楼层
 楼主| 发表于 2024-12-22 23:31:51 | 显示全部楼层
报错:
Using 'COM9' as serial port.
Connecting.....
Detecting chip type... ESP32-S3
Connecting.....
Chip Info:
 - Chip Family: ESP32
 - Chip Model: ESP32-S3
 - Number of Cores: 1
 - Max CPU Frequency: 80MHz
 - Has Bluetooth: NO
 - Has Embedded Flash: NO
 - Has Factory-Calibrated ADC: NO
 - MAC Address: F0:9E:9E:22:30:10
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
 - Flash Size: 16MB
Unexpected error: Error while retrieving firmware file 'https://raw.githubusercontent.com/espressif/arduino-esp32/1.0.4/tools/sdk/bin/bootloader_dio_80m.bin': HTTPSConnectionPool(host='raw.githubusercontent.com', port=443): Max retries exceeded with url: /espressif/arduino-esp32/1.0.4/tools/sdk/bin/bootloader_dio_80m.bin (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x000001F773C74460>: Failed to establish a new connection: [Errno 11004] getaddrinfo failed'))
发表于 2024-12-23 00:08:33 | 显示全部楼层
怎么这板子看着像单核没有蓝牙的?
Connecting....
Detecting chip type... Unsupported detection protocol, switching and trying again...
Connecting....
Connecting.....
Chip Info:
 - Chip Model: ESP32-D0WD-V3 (revision 3)
 - Number of Cores: 2
 - Max CPU Frequency: 240MHz
 - Has Bluetooth: YES
 - Has Factory-Calibrated ADC: YES
 - MAC Address: E4:65:B8:74:C0:B4
这是我的esp32的信息
 楼主| 发表于 2024-12-23 16:45:24 | 显示全部楼层
kjjuhfv 发表于 2024-12-23 00:08
怎么这板子看着像单核没有蓝牙的?
这是我的esp32的信息
其他刷入都正常,我另外还有esp32S,32-c3都能用就是S3用不了是不是我芯片问题,,。,。。但是arduino输入又能正常用
GMT+8, 2025-12-17 22:48 , Processed in 0.486853 second(s), 13 queries , MemCached On.
