查看: 1499|回复: 1
[求助] 新手求助一个sensor更新状态的问题
发表于 2024-12-21 22:56:52 | 显示全部楼层 |阅读模式
  - platform: rest
    name: Smart Light All States
    unique_id: smart_light_all_states
    resource: http://www/api/device/states
    method: POST
    headers:
      Content-Type: "application/json; charset=UTF-8"
    payload: >
        "deviceSn": "123"
    value_template: >
      {{ (value_json.result | length) | default(0) }}
    json_attributes:
      - result
    scan_interval: 10
template:
  - sensor:
      - name: "Restaurant Light State"
        unique_id: "restaurant_light_state"
        state: >
          {{ (state_attr('sensor.smart_light_all_states', 'result')
             | selectattr('st', '==', 10101)
             | selectattr('si', '==', 1)
             | map(attribute='fv')
             | list | first | default(0)) }}
      - name: "Living Room Light State"
        unique_id: "living_room_light_state"
        state: >
             | selectattr('si', '==', 2)
light:
  - platform: template
    lights:
      restaurant_light:
        unique_id: "restaurant_light_switch"
        value_template: "{{ is_state('sensor.restaurant_light_state', '1') }}"
        turn_on:
          sequence:
            - service: rest_command.restaurant_light_on
            - service: homeassistant.update_entity
              data:
                entity_id:
              data:
                entity_id:
        turn_off:
          sequence:
            - service: rest_command.restaurant_light_off
              data:
                entity_id:
              data:
                entity_id:
      living_light:
        unique_id: "living_light_switch"
        value_template: "{{ is_state('sensor.living_room_light_state', '1') }}"
        turn_on:
          sequence:
            - service: rest_command.living_light_on
              data:
                entity_id: sensor.smart_light_all_states
        turn_off:
          sequence:
            - service: rest_command.living_light_off
              data:
rest_command:
  restaurant_light_on:
    url: "http://www/api/device/control"
    method: post
    headers:
    payload: >
        "deviceSn": "123",
        "fn": 1,
        "fv": 1,
        "si": 1,
        "st": 10101
  restaurant_light_off:
    method: post
        "st": 10101
  living_light_on:
    method: post
    headers:
    payload: >
        "deviceSn": "123",
        "fn": 1,
        "fv": 1,
        "si": 2,
        "st": 10101
  living_light_off:
    url: "http://123/api/device/control"
    method: post
    headers:
    payload: >
        "deviceSn": "123",
        "fn": 1,
        "fv": 0,
        "si": 2,
        "st": 10101
这个是我配置的restful api的设备,sensor中配置了两个灯的状态轮询,并且灯的状态是通过这个来确定的,但是我在开灯的时候需要立刻更新这个值才能准确显示灯的状态
但是问题是,我在开灯的时候调用顺序调用homeassistant.update_entity,并没有起作用,有大佬帮忙看下么?
发表于 2024-12-24 19:27:52 | 显示全部楼层
I assume that your code is properly written in Home Assistant? I copied it as-is and there seems to be a typo in turn_on as -service instead of service .
GMT+8, 2026-1-3 07:01 , Processed in 0.286454 second(s), 16 queries , MemCached On.
