查看: 3358|回复: 10
[技术探讨] 更新core12.4后,zha就配置失败了。
发表于 2024-12-18 22:33:24 | 显示全部楼层 |阅读模式
今天看到小米出官方集成了。但是自己版本太低了。之前看到过有坛友发过帖子,说升级到12.0后,zha崩了。想着都到12.4了,估计修复了吧。就手贱更新到12.4了。现在ZHA崩了。删了ZHA重新配置也好,还是恢复备份也好,都配置失败。刚才有一次配置成功过,一会会又失败了。求各位大大求救啊。这是系统日志,哪位大佬能帮我看看啊?
Error setting up entry Socket://192.168.31.196:8888 for zha: Network settings do not match most recent backup
  File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 151, in async_setup_entry
    await zha_gateway.async_initialize()
  File "/usr/local/lib/python3.13/site-packages/zha/application/gateway.py", line 275, in async_initialize
    await self._async_initialize()
  File "/usr/local/lib/python3.13/site-packages/zha/application/gateway.py", line 258, in _async_initialize
    await self.application_controller.startup(auto_form=True)
  File "/usr/local/lib/python3.13/site-packages/zigpy/application.py", line 221, in startup
    await self.initialize(auto_form=auto_form)
  File "/usr/local/lib/python3.13/site-packages/zigpy/application.py", line 170, in initialize
    raise zigpy.exceptions.NetworkSettingsInconsistent(
    ...<5 lines>...
zigpy.exceptions.NetworkSettingsInconsistent: Radio network settings are not compatible with most recent backup!
Current settings: NetworkBackup(version=1, backup_time=datetime.datetime(2024, 12, 19, 8, 6, 13, 365114, tzinfo=datetime.timezone.utc), network_info=NetworkInfo(extended_pan_id=1f:cb:97:55:50:36:db:e0, pan_id=0x45E1, nwk_update_id=0, nwk_manager_id=0x0000, channel=11, channel_mask=<Channels.ALL_CHANNELS: 134215680>, security_level=5, network_key=Key(key=5b:c6:a4:b8:f3:d1:c6:f5:bf:2c:0f:05:6d:79:e9:8e, tx_counter=45057, rx_counter=0, seq=0, partner_ieee=ff:ff:ff:ff:ff:ff:ff:ff), tc_link_key=Key(key=5a:69:67:42:65:65:41:6c:6c:69:61:6e:63:65:30:39, tx_counter=4096, rx_counter=0, seq=0, partner_ieee=00:00:00:00:10:00:00:00), key_table=[], children=[], nwk_addresses={}, stack_specific={'ezsp': {'hashed_tclk': 'a9aecc68df2bb5d430791e8f3a709e75'}}, metadata={'ezsp': {'stack_version': 7, 'can_burn_userdata_custom_eui64': False, 'can_rewrite_custom_eui64': False, 'flow_control': None}}, source='[email protected]'), node_info=NodeInfo(nwk=0x0000, ieee=00:00:00:00:10:00:00:00, logical_type=<LogicalType.Coordinator: 0>, model=None, manufacturer=None, version='6.6.6.0 build 218'))
Last backup: NetworkBackup(version=1, backup_time=datetime.datetime(2024, 12, 19, 7, 36, 21, 556510, tzinfo=datetime.timezone.utc), network_info=NetworkInfo(extended_pan_id=1f:cb:97:55:50:36:db:e0, pan_id=0x45E1, nwk_update_id=0, nwk_manager_id=0x0000, channel=11, channel_mask=<Channels.ALL_CHANNELS: 134215680>, security_level=5, network_key=Key(key=5b:c6:a4:b8:f3:d1:c6:f5:bf:2c:0f:05:6d:79:e9:8e, tx_counter=36867, rx_counter=0, seq=0, partner_ieee=ff:ff:ff:ff:ff:ff:ff:ff), tc_link_key=Key(key=5a:69:67:42:65:65:41:6c:6c:69:61:6e:63:65:30:39, tx_counter=4096, rx_counter=0, seq=0, partner_ieee=47:c5:11:80:df:8c:cf:04), key_table=[], children=[], nwk_addresses={}, stack_specific={'ezsp': {'hashed_tclk': 'a9aecc68df2bb5d430791e8f3a709e75'}}, metadata={'ezsp': {'stack_version': 7, 'can_burn_userdata_custom_eui64': False, 'can_rewrite_custom_eui64': False, 'flow_control': None}}, source='[email protected]'), node_info=NodeInfo(nwk=0x0000, ieee=47:c5:11:80:df:8c:cf:04, logical_type=<LogicalType.Coordinator: 0>, model=None, manufacturer=None, version='6.6.6.0 build 218'))
The above exception was the direct cause of the following exception:
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 640, in __async_setup_with_context
    result = await component.async_setup_entry(hass, self)
  File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 159, in async_setup_entry
    raise ConfigEntryError(
        "Network settings do not match most recent backup"
    ) from exc
homeassistant.exceptions.ConfigEntryError: Network settings do not match most recent backup
发表于 2024-12-18 23:50:27 | 显示全部楼层
冬瓜版的更新后 zha 正常
 楼主| 发表于 2024-12-18 23:53:00 | 显示全部楼层
mikebai521 发表于 2024-12-18 23:50
冬瓜版的更新后 zha 正常
要重装冬瓜版的ha os系统?
发表于 2024-12-19 08:13:38 | 显示全部楼层
misLia 发表于 2024-12-18 23:53
要重装冬瓜版的ha os系统?
我的HA主机就是冬瓜版的,也就一直跟着更新,ZHA一直在用,目前正常
 楼主| 发表于 2024-12-19 08:48:02 | 显示全部楼层
我海鲜市场买的主机。用的supervisor的系统。崩溃啊。现在退回到10.1了。不过好像还是有点问题。
发表于 2024-12-19 09:56:44 | 显示全部楼层
misLia 发表于 2024-12-19 08:48
我海鲜市场买的主机。用的supervisor的系统。崩溃啊。现在退回到10.1了。不过好像还是有点问题。 ...
我的是昨儿下午3点,突然涂鸦和xiaomi miot auto就都挂了
至今还挂着。
 楼主| 发表于 2024-12-19 12:09:20 | 显示全部楼层
大家真的都没问题吗?
发表于 2024-12-23 23:00:22 | 显示全部楼层
misLia 发表于 2024-12-19 12:09
大家真的都没问题吗?
我一点问题木有,都是有更新就直接更新。我特意用的X86主机安装的完整版,就是拍出现你这样的各种莫名其妙的问题
发表于 2024-12-24 22:13:23 | 显示全部楼层
问题解决没
 楼主| 发表于 2024-12-26 09:22:45 | 显示全部楼层
没。我升级到12.4,就跳出“网络设置与最近备份不同”。删除全部设备,重新配置新的网络,只要重载ZHA,就跳出“网络设置与最近备份不同”。然后降级到11.1 11.2 11.3 不会在出现“网络设置与最近备份不同”,但是有些设备无法添加,即便添加进ZHA,也是“不可用”或者几分钟后就无法再控制了。
GMT+8, 2026-1-14 21:12 , Processed in 0.056440 second(s), 12 queries , MemCached On.
