查看: 1592|回复: 3
[求助] esphome 编译出错
发表于 2024-12-8 11:00:22 | 显示全部楼层 |阅读模式
编一个欧博瑞30W的程序。老是出错
请大家帮看看。这一句要怎样才能不错
esphome:
  friendly_name: my_espir
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "G0IFfRABuEQ//a2j3ER9w7MM56Hl+PoWERWC6vGY0vk="
  services:
    - service: ir_raw
      variables:
        command: int[]
      then:
        - remote_transmitter.transmit_raw
            code: !lambda 'return command'
            carrier_frequency: 38k
ota:
  - platform: esphome
    password: "101107"
wifi:
  ssid: "JUN"
  password: "8899334411"
  ap:
    ssid: "My-Espir Fallback Hotspot"
captive_portal:
错的是 code: !lambda 'return command'这一句。
显示
INFO ESPHome 2024.11.3INFO Reading configuration /config/esphome/my-espir.yaml...ERROR Error while reading config: Invalid YAML syntax:mapping values are not allowed here  in "/config/esphome/my-espir.yaml", line 21, column 17
发表于 2024-12-8 14:44:38 | 显示全部楼层
我的是這樣
# 啟用家庭助理 API
api:
  services:
    - service: send_raw_command
      variables:
        command: int[]
      then:
        - remote_transmitter.transmit_raw:
            code: !lambda 'return command;'
            carrier_frequency: 38kHz
发表于 2024-12-8 18:18:33 | 显示全部楼层
代码要贴完出来
这样看不出来是不是没有设置发射端
 楼主| 发表于 2024-12-9 20:00:40 | 显示全部楼层
经过半天的研究,终于搞定了,谢谢上面两位朋友的解答。
GMT+8, 2025-12-17 20:48 , Processed in 0.066830 second(s), 14 queries , MemCached On.
