查看: 1643|回复: 4
[求助] 开灯数量统计显示 0
发表于 2024-11-27 22:20:08 | 显示全部楼层 |阅读模式
{% set all = expand('sensor.number_lights_on')| list -%} {% set ND1 =
all | selectattr('state','eq','on')|list|count%} {% set D1 = all |
selectattr('state','eq','off')|list|count%}
{{ND1}}盏灯
HomeAssistant
发表于 2024-11-28 08:36:26 | 显示全部楼层
试试这个
{{ states.light | selectattr('state', 'equalto', 'on') | list | length }}
发表于 2024-11-29 12:04:01 | 显示全部楼层
我的sensors.yaml是這樣寫的,下面那些entity是要排除計算的設備。
- platform: template
  sensors:
    number_lights_on:
      friendly_name: 開燈數量
      value_template: >-
        {{ expand(states.light, states.switch)
        | selectattr('state', 'eq', 'on')
        | rejectattr('attributes.entity_id', 'defined')
        | rejectattr('entity_id','in',
         'switch.xi_yi_ji_zhi_neng_cha_zuo_child_lock',
         'switch.xi_yi_ji_zhi_neng_cha_zuo_socket_1',
         'switch.wellbeing_kong_qi_qing_jing_ji_safetylock',
         'switch.wellbeing_kong_qi_qing_jing_ji_uilight',
         'switch.wellbeing_kong_qi_qing_jing_ji_ionizer',
         'light.izq_ble_02ee_indicator_light',
         'switch.tp_link_tapo_p306_smart_plug_4',
         'switch.tp_link_tapo_p306_smart_plug_1',
         'switch.tp_link_tapo_p306_smart_plug_2',
         'switch.tp_link_tapo_p306_smart_plug_3',
         'switch.switch.zhu_wo_xiao_ye_deng_zhi_neng_cha_zuo_child_lock',
         'switch.light.54ef446357c0_led'
发表于 2024-12-1 17:49:23 | 显示全部楼层
    sensors:
        number_lights_on:
            friendly_name: 开灯数量
            value_template: "{{ states.light | selectattr('state','eq','on') | selectattr('attributes.friendly_name','search','灯') |list |count + states.input_boolean | selectattr('state','eq','on') | selectattr('attributes.friendly_name','search','灯') |list |count }}"
在configuration.yaml定义上面的变量
设备名子里要带个“灯”字哟。
有些设备是开关,还有一些是自己定义的辅助元素,所以都加块了。
 楼主| 发表于 2024-12-1 19:06:20 | 显示全部楼层
kuoyeh 发表于 2024-12-1 17:49
谢谢可以了
GMT+8, 2025-12-17 22:15 , Processed in 1.267222 second(s), 15 queries , MemCached On.
