查看: 14391|回复: 6
[求助] 小米网关接入问题
发表于 2018-2-8 22:02:43 | 显示全部楼层 |阅读模式
彩云天气一直装不好,想是不是要升级系统,就按教程把先把ha升到了0.62.1
然后小米网关就出问题了,配置文件改好了,应该没问题
xiaomi_aqara:
  discovery_retry: 5
  gateways:
    - key: xxxxxxxxx
错误提示pyxiaomigateway==0.8.0
然后开始安装0.8.0
pip3 install pyxiaomigateway==0.8.0
这里又出错,提示python_version <'3'
,我查了下目录 /usr/lib 下面有python2.7和python3.4两个目录,里面文件都有的,怎么解决呢?
发表于 2018-2-9 16:16:43 | 显示全部楼层
我也是一样的问题,群晖DSM5.2,docker安装的HA
发表于 2018-2-9 22:31:36 | 显示全部楼层
同装不上这个依赖
发表于 2018-2-9 22:47:17 | 显示全部楼层
找到解决办法了,安装 sudo apt-get install libffi-dev libssl-dev  这两个依赖,然后安装python-miio插件,就可以了
发表于 2018-2-9 22:54:08 | 显示全部楼层
sudo su -s /bin/bash homeassistant
source /srv/homeassistant/homeassistant_venv/bin/activate
pip3 install python-miio
pip3 install PyXiaomiGateway
 楼主| 发表于 2018-2-10 09:54:11 | 显示全部楼层
非常感谢回复,第三步错误提示:
homeassistant@raspberrypi:/home/pi $ source /srv/homeassistant/homeassistant_venv/bin/activate
bash: /srv/homeassistant/homeassistant_venv/bin/activate: No such file or directory
尝试了改为 source /srv/homeassistant/bin/activate 可以通过,但第四步又有问题了,错误提示:
(homeassistant) homeassistant@raspberrypi:/home/pi $ pip3 install python-miio
pip is configured with locations that require TLS/SSL, however the ssl module in Python is not available.
Collecting python-miio
  Could not fetch URL https://pypi.python.org/simple/python-miio/: There was a problem confirming the ssl certificate: Can't connect to HTTPS URL because the SSL module is not available. - skipping
  Could not find a version that satisfies the requirement python-miio (from versions: )
No matching distribution found for python-miio
 楼主| 发表于 2018-2-10 22:30:37 | 显示全部楼层
第三步 查看了下文件目录,确实没有教程中那个/homeassistant_venv 目录
GMT+8, 2025-12-16 08:30 , Processed in 1.251349 second(s), 14 queries , MemCached On.
