查看: 1554|回复: 2
[求助] KNX添加空调,控制模式对应不上如何解决
发表于 2024-11-20 21:58:17 | 显示全部楼层 |阅读模式
knx:
  climate:
    - name: "客厅地暖"
      temperature_address: "11/4/0"
      target_temperature_address: "13/3/0"
      target_temperature_state_address: "14/3/0"
      temperature_step: 1.0
      min_temp: 16.0
      max_temp: 35.0
      on_off_address: "13/1/0"
      on_off_state_address: "14/1/0"
      operation_modes: ['STANDBY', 'COMFORT', 'BUILDING_PROTECTION', 'ECONOMY', 'AUTO']
      operation_mode_address: "13/2/0"
      operation_mode_state_address: "14/2/0"
      command_value_state_address: "14/2/0"
    - name: "客厅空调"
      target_temperature_address: "12/3/0"
      target_temperature_state_address: "11/3/0"
      min_temp: 16.0
      max_temp: 35.0
      on_off_address: "12/0/0"
      on_off_state_address: "11/0/0"
      controller_modes: ['Cool',  'Heat', 'Fan only', 'Dry', 'Auto', 'Off']
      controller_mode_address: "12/1/0"
      controller_mode_state_address: "11/1/0"
      command_value_state_address: "11/1/0"
      operation_modes: ['AUTO', 'BUILDING_PROTECTION', 'STANDBY', 'COMFORT']
      operation_mode_address: "12/2/0"
      operation_mode_state_address: "11/2/0"
      command_value_state_address: "11/2/0"
客厅空调,控制模式有些是对的,有些是反的;另外,没法用NODERED,一用NODERED,KNX就掉线,应该是厂家只允许一个接入
发表于 2024-12-1 11:12:29 | 显示全部楼层
  climate:
    - name: "办公室空调"
      temperature_address: '11/4/1'
      target_temperature_address: '12/3/1'
      target_temperature_state_address: '11/3/1'
      min_temp: 16.0
      max_temp: 30.0
      on_off_address: "12/0/1"
      on_off_state_address: "11/0/1"
      controller_modes: ['Cool', 'Dry', 'Fan only', 'Heat', 'Auto']
      controller_mode_address: "12/1/1"
      controller_mode_state_address: "11/1/1"
      fan_speed_address: "12/2/1"
      fan_speed_state_address: "11/2/1"
      fan_max_step: 3
      fan_speed_mode: step
你试下用这个!其中模式的值是固定的,目前我是不会修改的办法【0-Auto,1-Heat,3-Cool,9- Fan Only,14Dry】
风速【0关闭,1低俗,2中速,3高速】
发表于 2024-12-2 14:49:34 | 显示全部楼层
knx里面模式就是对不上的,因为knx是国外的用的是水暖加湿那套逻辑,跟国内的不一样,想要对的上得用nodered,用homekit节点和knx节点,或者mqtt
GMT+8, 2025-12-17 22:13 , Processed in 1.005354 second(s), 6 queries , MemCached On.
