查看: 1884|回复: 2
[技术探讨] 想用一个esp模块控制2~3路输出风扇的速度控制
发表于 2024-11-20 20:50:06 | 显示全部楼层 |阅读模式
一个esp8266 模块 现在 是一路风扇速度控制 一个光线传感器 一个温湿度传感器 代码如下:
substitutions:
  device_name: "Super Fan"
  device_name_low: "super-fan"
  comment: "Super Fan"
  version: "1.0.0"
  speed_low: "50"
  speed_med: "75"
  speed_full: "100"
esphome:
  project:
    version: "${version}"
  on_boot:
    then:
      - delay: 10s
      - fan.turn_on:
          speed: "${speed_low}"
      - delay: 5s
      - fan.turn_on:
          speed: "${speed_full}"
  friendly_name: 散热风扇调速 控制系统
  comment: 散热风扇调速 50%,75%,100%,带温湿度传感器,控制系统。
esp8266:
  board: d1_mini_lite
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "wsWjDf+9Ooe****m4lWy3TniUnSAzOTHuYqSo6cNMOQ="
ota:
  - platform: esphome
    password: "8***24a3cd15d1416928b3b066443cc"
wifi:
  ssid: "**"
  password: "********"
  ap:
    ssid: "***"
    password: "88888888"
captive_portal:
web_server:
  port: 80
i2c:
  sda: GPIO4
  scl: GPIO5
  scan: true
output:
  - platform: esp8266_pwm
    pin: GPIO02
    frequency: 15000 Hz
fan:
  - platform: speed
    output: pwm_output
    speed_count: 100
number:
  - platform: template
    icon: "mdi:fan"
    lambda: |-
      return id(fan_speed).speed;
    step: 1
    min_value: 1
    max_value: 100
    unit_of_measurement: "%"
    update_interval: 1s
    set_action:
      then:
        - fan.turn_on:
            speed: !lambda "return x;"
        - component.update: fanmode
        - component.update: sensor_fanspeed
select:
    icon: "mdi:fan"
    update_interval: 1s
    lambda: |-
      if(id(fan_speed).speed <= ${speed_low})
        return std::string("Low");
      else if(id(fan_speed).speed == ${speed_med})
        return std::string("Medium");
      else if(id(fan_speed).speed >= ${speed_full})
        return std::string("Full");
      else
        return std::string("Custom");
    set_action:
      then:
        - lambda: |-
            auto call = id(fan_speed).turn_on();
            if(x == "Low")
              call.set_speed(${speed_low});
            else if(x == "Medium")
              call.set_speed(${speed_med});
            else if(x == "Full")
              call.set_speed(${speed_full});
            else
              call.set_speed(id(speed_input).state);
            call.perform();
        - component.update: speed_input
    options:
      - Low
      - Medium
      - Full
      - Custom
button:
    icon: "mdi:fan-speed-1"
    on_press:
      - fan.turn_on:
    icon: "mdi:fan-speed-2"
    on_press:
      - fan.turn_on:
          speed: "${speed_med}"
    icon: "mdi:fan-speed-3"
    on_press:
      - fan.turn_on:
  - platform: restart
    icon: "mdi:fan"
    lambda: |-
    update_interval: 1s
    accuracy_decimals: 0
  - platform: dht
    pin: D7
    temperature:
      name: "Living Room Temperature"
    humidity:
      name: "Living Room Humidity"
    update_interval: 30s
  - platform: bh1750
    i2c_id: bus_a
    name: "BH1750 Illuminance"
    address: 0x23
光线传感器可以不要 现在想多几路风扇调速输出,求指教,这样就可以用一个模块 控制几路风扇用于弱电箱不同位置的散热。
发表于 2024-12-1 01:10:56 | 显示全部楼层
这个输出的pwm信号可以控制4线电脑风扇的速度嘛
 楼主| 发表于 2024-12-1 09:19:48 | 显示全部楼层
只有一路
GMT+8, 2025-12-25 15:13 , Processed in 0.263481 second(s), 5 queries , MemCached On.
