查看: 2351|回复: 2
[技术探讨] 纯小白 在线跪求大佬指点 , 2天了 卡在最后一步 救救我....
发表于 2024-11-18 19:31:24 | 显示全部楼层 |阅读模式
最近2天在学习 机顶盒 刷home assistent      本人纯小白  一步一步跟着冬瓜大佬的教程 刷成功了 ,但是卡在这最后一步 一下午了
初始化页面一直提示这个   一下午了 ,  应该如何解决,   望各位支招、  谢谢谢谢谢谢
[tr][/tr]
hassio-supervisor
INFO: Using udev information from host
INFO: Starting local supervisor watchdog...
[__main__] Initializing Supervisor setup
[supervisor.bootstrap] Setting up coresys for machine: odroid-c4
[supervisor.docker.supervisor] Attaching to Supervisor m.fashgh.com/home-assistant/aarch64-hassio-supervisor with version 2024.11.2
[supervisor.docker.supervisor] Connecting Supervisor to hassio-network
[supervisor.resolution.evaluate] Starting system evaluation with state initialize
[supervisor.resolution.evaluate] System evaluation complete
[__main__] Setting up Supervisor
[supervisor.api] Starting API on 172.30.32.2
[supervisor.hardware.monitor] Started Supervisor hardware monitor
[supervisor.dbus.manager] Connected to system D-Bus.
[supervisor.dbus.agent] Load dbus interface io.hass.os
[supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
[supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
[supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
[supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
[supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
[supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
[supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
[supervisor.host.services] Updating service information
[supervisor.host.sound] Updating PulseAudio information
[supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
[supervisor.host.network] Updating local network information
[supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
[supervisor.docker.monitor] Started docker events monitor
[supervisor.updater] Fetching update data from https://version.wghaos.com/s905l ... 2024.11.2&arch=
[supervisor.docker.interface] Attaching to m.fashgh.com/home-assistant/aarch64-hassio-cli with version 2024.09.0
[supervisor.plugins.cli] Starting CLI plugin
[supervisor.docker.manager] Cleaning hassio_cli application
[supervisor.docker.cli] Starting CLI m.fashgh.com/home-assistant/aarch64-hassio-cli with version 2024.09.0 - 172.30.32.5
[supervisor.docker.interface] Attaching to m.fashgh.com/home-assistant/aarch64-hassio-dns with version 2024.04.0
[supervisor.plugins.dns] Starting CoreDNS plugin
[supervisor.docker.manager] Cleaning hassio_dns application
[supervisor.docker.dns] Starting DNS m.fashgh.com/home-assistant/aarch64-hassio-dns with version 2024.04.0 - 172.30.32.3
[supervisor.plugins.dns] Updated /etc/resolv.conf
[supervisor.docker.interface] Attaching to m.fashgh.com/home-assistant/aarch64-hassio-audio with version 2023.12.0
[supervisor.plugins.audio] Starting Audio plugin
[supervisor.docker.manager] Cleaning hassio_audio application
[supervisor.docker.audio] Starting Audio m.fashgh.com/home-assistant/aarch64-hassio-audio with version 2023.12.0 - 172.30.32.4
[supervisor.docker.interface] Attaching to m.fashgh.com/home-assistant/aarch64-hassio-observer with version 2023.06.0
[supervisor.docker.interface] Attaching to m.fashgh.com/home-assistant/aarch64-hassio-multicast with version 2024.03.0
[supervisor.plugins.multicast] Starting Multicast plugin
[supervisor.docker.manager] Cleaning hassio_multicast application
[supervisor.docker.multicast] Starting Multicast m.fashgh.com/home-assistant/aarch64-hassio-multicast with version 2024.03.0 - Host
[supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
[supervisor.docker.interface] Attaching to m.fashgh.com/home-assistant/odroid-c4-homeassistant with version landingpage
[supervisor.homeassistant.core] Starting HomeAssistant landingpage
[supervisor.docker.manager] Starting homeassistant
[supervisor.os.manager] Detect Home Assistant Operating System 13.2 / BootSlot A
[supervisor.store.git] Loading add-on /data/addons/git/fb59d657 repository
[supervisor.store.git] Loading add-on /data/addons/git/d6faf732 repository
[supervisor.store.git] Loading add-on /data/addons/core repository
[supervisor.store.git] Loading add-on /data/addons/git/b9a594eb repository
[supervisor.store] Loading add-ons from store: 80 all - 80 new - 0 remove
[supervisor.addons.manager] Found 0 installed add-ons
[supervisor.backups.manager] Found 0 backup files
[supervisor.discovery] Loaded 0 messages
[supervisor.ingress] Loaded 0 ingress sessions
[supervisor.resolution.check] Starting system checks with state setup
[supervisor.resolution.checks.base] Run check for disabled_data_disk/system
[supervisor.resolution.checks.base] Run check for detached_addon_missing/addon
[supervisor.resolution.checks.base] Run check for multiple_data_disks/system
[supervisor.resolution.checks.base] Run check for detached_addon_removed/addon
[supervisor.resolution.check] System checks complete
[supervisor.resolution.evaluate] Starting system evaluation with state setup
[supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
[__main__] Running Supervisor
[supervisor.os.manager] Rauc: slot A - activated slot kernel.0, marked slot kernel.0 as good
[supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
[supervisor.addons.manager] Phase 'system' starting 0 add-ons
[supervisor.addons.manager] Phase 'services' starting 0 add-ons
[supervisor.core] Skipping start of Home Assistant
[supervisor.addons.manager] Phase 'application' starting 0 add-ons
[supervisor.misc.tasks] All core tasks are scheduled
[supervisor.core] Supervisor is up and running
[supervisor.homeassistant.core] Home Assistant setup
[supervisor.docker.interface] Updating image m.fashgh.com/home-assistant/odroid-c4-homeassistant:landingpage to m.fashgh.com/home-assistant/odroid-c4-homeassistant:2024.11
[supervisor.docker.interface] Downloading docker image m.fashgh.com/home-assistant/odroid-c4-homeassistant with tag 2024.11.
[supervisor.host.info] Updating local host information
[supervisor.resolution.check] Starting system checks with state running
[supervisor.resolution.checks.base] Run check for docker_config/system
[supervisor.resolution.checks.base] Run check for no_current_backup/system
[supervisor.resolution.module] Create new suggestion create_full_backup - system / None
[supervisor.resolution.module] Create new issue no_current_backup - system / None
[supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
[supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
[supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
[supervisor.resolution.checks.base] Run check for trust/supervisor
[supervisor.resolution.checks.base] Run check for pwned/addon
[supervisor.resolution.checks.base] Run check for free_space/system
[supervisor.resolution.checks.base] Run check for security/core
[supervisor.resolution.evaluate] Starting system evaluation with state running
[supervisor.host.manager] Host information reload completed
[supervisor.resolution.fixup] Starting system autofix at state running
[supervisor.resolution.fixup] System autofix complete
[supervisor.docker.interface] Can't install m.fashgh.com/home-assistant/odroid-c4-homeassistant:2024.11: 404 Client Error for http+docker://localhost/v1.47/images/create?tag=2024.11&fromImage=m.fashgh.com%2Fhome-assistant%2Fodroid-c4-homeassistant&platform=linux%2Farm64: Not Found ("manifest for m.fashgh.com/home-assistant/odroid-c4-homeassistant:2024.11 not found: manifest unknown: manifest unknown")
[supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
回复 编辑
[url=]使用道具[/url] [url=]评分[/url]
QQ779123
帖子
积分24金钱19HASS币0
783#
发表于 1 小时前 | 只看该作者
f@me 发表于 2024-11-18 14:55
core版本不对,日志贴全一点
hassio-supervisor
s6-rc: info: 服务 s6rc-oneshot-runner: 启动
s6-rc: info: 服务 s6rc-oneshot-runner 成功启动
s6-rc: 信息: 服务 fix-attrs: 启动
s6-rc: 信息: 服务 fix-attrs successfully started
s6-rc: 信息: 服务 legacy-cont-init: 启动
cont-init: 信息: 运行 /etc/cont-init.d/udev.sh
信息: 使用主机
cont-init 中的 udev 信息: 信息: /etc/cont-init.d/udev.sh退出 0
s6-rc: 信息: 服务 legacy-cont-init 已成功启动
s6-rc: 信息: 服务 legacy-services: 启动
服务启动: 信息: 复制旧版 LongRun 监督器(无就绪通知)
服务启动: 信息: 复制旧版 LongRun 看门狗(无就绪通知)
s6-rc: 信息: 服务 legacy-services 已成功启动
信息: 正在启动本地监督器看门狗...
[__main__] 初始化 Supervisor 设置
[supervisor.bootstrap] 为计算机 odroid-c4 设置 coresys
[supervisor.docker.supervisor] 连接到版本 2024.11.2 的 Supervisor m.fashgh.com/home-assistant/aarch64-hassio-supervisor
[supervisor.docker.supervisor] 将 Supervisor 连接到 hassio-network
[supervisor.resolution.evaluate] 使用状态初始化
启动系统评估[supervisor.resolution.evaluate] 系统评估完成
[__main__] 设置监控器
[supervisor.api] 在 172.30.32.2 上启动 API
[supervisor.hardware.monitor] 已启动 Supervisor 硬件监控器
[supervisor.dbus.manager] 连接到系统 D-Bus。
[supervisor.dbus.agent] 加载 dbus 接口 io.hass.os
[supervisor.dbus.hostname] 加载 dbus 接口 org.freedesktop.hostname1
[supervisor.dbus.logind] 加载 dbus 接口 org.freedesktop.login1
[supervisor.dbus.network] 加载 dbus 接口 org.freedesktop.NetworkManager
[supervisor.dbus.rauc] 加载 dbus 接口 de.pengutronix.rauc
[supervisor.dbus.resolved] 加载 dbus 接口org.freedesktop.resolve1
[supervisor.dbus.systemd] 加载 dbus 接口 org.freedesktop.systemd1
[supervisor.dbus.timedate] 加载 dbus 接口 org.freedesktop.timedate1
[supervisor.host.services] 正在更新服务信息
[supervisor.host.sound] 正在更新 PulseAudio 信息
[supervisor.host.sound] 无法更新 PulseAudio 数据:无法连接到 pulseaudio 服务器
[supervisor.host.network] 正在更新本地网络信息
[supervisor.host.apparmor] 正在加载 AppArmor 配置文件: {'hassio-supervisor'}
[supervisor.docker.monitor] 已启动 docker 事件监视器
[supervisor.updater] 正在从 https://version.wghaos.com/s905l ...2024.11.2&arch=
[supervisor.docker.interface] 连接到版本 2024.09.0 的 m.fashgh.com/home-assistant/aarch64-hassio-cli
[supervisor.plugins.cli] 启动 CLI 插件
[supervisor.docker.manager] 清理hassio_cli应用程序
[supervisor.docker.cli] 启动版本 2024.09.0 - 172.30.32.5
的 CLI m.fashgh.com/home-assistant/aarch64-hassio-cli[supervisor.docker.interface] 附加到版本 2024.04 的 m.fashgh.com/home-assistant/aarch64-hassio-dns。0
[supervisor.plugins.dns] 启动 CoreDNS 插件
[supervisor.docker.manager] 清理hassio_dns应用程序
[supervisor.docker.dns] 启动版本 2024.04.0 的 DNS m.fashgh.com/home-assistant/aarch64-hassio-dns - 172.30.32.3
[supervisor.plugins.dns] 更新的 /etc/resolv.conf
[supervisor.docker.interface] 附加到版本 2023.12.0
的 m.fashgh.com/home-assistant/aarch64-hassio-audio[supervisor.plugins.audio] 启动音频插件
[supervisor.docker.manager] 清理hassio_audio应用程序
[supervisor.docker.audio] 启动版本 2023.12.0 - 172.30.32.4 的音频 m.fashgh.com/home-assistant/aarch64-hassio-audio
[supervisor.docker.interface] 连接到版本 2023.06.0
的 m.fashgh.com/home-assistant/aarch64-hassio-observer[supervisor.docker.interface] 连接到版本 2024.03.0 的 m.fashgh.com/home-assistant/aarch64-hassio-multicast
[supervisor.plugins.multicast] 启动多播插件
[supervisor.docker.manager] 清理hassio_multicast应用程序
[supervisor.docker.multicast] 使用版本 2024.03.0 启动多播 m.fashgh.com/home-assistant/aarch64-hassio-multicast - 主机
[supervisor.homeassistant.secrets] 加载 0 主页Assistant 密钥
[supervisor.docker.interface] 使用版本登录页面附加到 m.fashgh.com/home-assistant/odroid-c4-homeassistant
[supervisor.homeassistant.core] 启动 HomeAssistant 登录页面
[supervisor.docker.manager] 启动 homeassistant
[supervisor.os.manager] 检测 Home Assistant 操作系统 13.2 / BootSlot A
[supervisor.store.git] 加载附加组件 /data/addons/git/fb59d657 存储库
[supervisor.store.git] 加载附加组件 /data/addons/git/d6faf732 仓库
[supervisor.store.git] 加载附加组件 /data/addons/core 仓库
[supervisor.store.git] 加载附加组件 /data/addons/git/b9a594eb 仓库
[supervisor.store] 从商店加载附加组件:80 个全部 - 80 个新 - 0 个删除
[supervisor.addons.manager] 找到 0 个已安装的附加组件
[supervisor.backups.manager] 找到 0 个备份文件
[supervisor.discovery] 加载了 0 条消息
[supervisor.ingress] 加载了 0 个入口会话
[supervisor.resolution.check] 使用状态设置
启动系统检查 [supervisor.resolution.checks.base] 运行disabled_data_disk/系统的
检查 [supervisor.resolution.checks.base] 运行detached_addon_missing/插件的检查
[supervisor.resolution.checks.base] 运行multiple_data_disks/系统的
检查[supervisor.resolution.checks.base] 运行detached_addon_removed/插件的检查
[supervisor.resolution.check] 系统检查完成
[supervisor.resolution.evaluate] 使用状态设置
开始系统评估 [supervisor.resolution.evaluate] 系统评估完成
[supervisor.jobs] 阻止执行“ResolutionFixup.run_autofix”,系统未运行 - 设置
[__main__] 运行监督器
[supervisor.os.manager] Rauc:插槽 A - 激活的插槽 kernel.0,市场d slot kernel.0 一样好
[supervisor.addons.manager] 阶段 '初始化' 开始 0 个
附加组件 [supervisor.addons.manager] 阶段 'system' 开始 0 个附加组件
[supervisor.addons.manager] 阶段 '服务' 开始 0 个
附加组件 [supervisor.core] 跳过家庭助理
的启动 [supervisor.addons.manager] 阶段 '应用程序' 开始 0 个
附加组件 [supervisor.misc.tasks] 所有核心任务都已计划
[supervisor.core] Supervisor 已启动并运行
[supervisor.homeassistant.core] Home Assistant 设置
[supervisor.docker.interface] 正在将映像 m.fashgh.com/home-assistant/odroid-c4-homeassistant:landingpage 更新为 m.fashgh.com/home-assistant/odroid-c4-homeassistant:2024.11
[supervisor.docker.interface] 正在下载带有标签 2024.11 的 docker 映像 m.fashgh.com/home-assistant/odroid-c4-homeassistant。
[supervisor.host.info] 更新本地主机信息
[supervisor.resolution.check] 在状态运行时
启动系统检查 [supervisor.resolution.checks.base] 运行docker_config/系统的
检查 [supervisor.resolution.checks.base] 运行no_current_backup/system
的检查[supervisor.resolution.module] 创建新建议create_full_backup - 系统 / 无
[supervisor.resolution.module] 创建新问题 no_current_backup - 系统 / 无
[supervisor.resolution.checks.base] 运行ipv4_connection_problem/系统的
检查 [supervisor.resolution.checks.base] 运行dns_server_ipv6_error/dns_server的检查
[supervisor.resolution.checks.base] 运行dns_server_failed/dns_server
的检查[supervisor.resolution.checks.base] 运行信任/监控程序检查
[supervisor.resolution.checks.base] 运行检查pwned/插件
[supervisor.resolution.checks.base] 运行检查free_space/系统
[supervisor.resolution.checks.base] 运行安全/核心
检查 [supervisor.resolution.check] 系统检查完成
[supervisor.resolution.evaluate] 在状态运行时
启动系统评估 [supervisor.host.services] 更新服务信息
[supervisor.host.network] 更新本地网络信息
[supervisor.host.sound] 更新 PulseAudio 信息
[supervisor.host.manager] 主机信息重新加载完成
[supervisor.resolution.fixup] 在运行
状态下启动系统自动修复 [supervisor.resolution.fixup] 系统自动修复完成
[supervisor.docker.interface] 无法安装 m.fashgh.com/home-assistant/odroid-c4-homeassistant:2024.11:http+docker://localhost/v1.47/images/create?tag=2024.11&fromImage=m.fashgh.com%2Fhome-assistant%2Fodroid-c4-homeassistant&platform=linux%2Farm64 的 404 客户端错误:未找到(“清单m.fashgh.com/home-assistant/odroid-c4-homeassistant:2024.11 未找到:清单未知:清单未知“)
[supervisor.homeassistant.core] Home Assistant 安装错误。在 30 秒
内重试 [supervisor.docker.interface] 正在更新 im.fashgh.com/home-assistant/odroid-c4-homeassistant:2024.11 的 mage m.fashgh.com/home-assistant/odroid-c4-homeassistant:landingpage
[supervisor.docker.interface] 下载带有标签 2024.11 的 docker 镜像 m.fashgh.com/home-assistant/odroid-c4-homeassistant。
[supervisor.docker.interface] 无法安装 m.fashgh.com/home-assistant/odroid-c4-homeassistant:2024.11:http+docker://localhost/v1.47/images/create?tag=2024.11&fromImage=m.fashgh.com%2Fhome-assistant%2Fodroid-c4-homeassistant&platform=linux%2Farm64 的 404 客户端错误:未找到(“找不到 m.fashgh.com/home-assistant/odroid-c4-homeassistant:2024.11 的清单:清单未知:清单未知”)
内重试 [supervisor.docker.interface] 将映像 m.fashgh.com/home-assistant/odroid-c4-homeassistant:landingpage 更新为 m.fashgh.com/home-assistant/odroid-c4-homeassistant:2024.11
[supervisor.docker.interface] 下载带有标签 2024.11 的 docker 映像 m.fashgh.com/home-assistant/odroid-c4-homeassistant。
内重试 [supervisor.docker.interface] 更新映像 m.fashgh.com/home-assistant/odroid-c4-homeassistant:landingpagem.fashgh.com/home-assistant/odroid-c4-homeassistant:2024.11
[supervisor.homeassistant.core] Home Assistant 安装错误。在 30 秒内重试
发表于 2024-11-18 19:52:26 | 显示全部楼层
一直卡着  网络问题吧
发表于 2024-11-18 20:16:21 | 显示全部楼层
dns 解析和网络问题 DNS 可以设置为未污染的 通道 8.8.8.8 至于网络就要看情况了
有一些 语音视频SIP电话和ESP插板出同时调试一些路由如routeros 爱快 和 接入网设备
GMT+8, 2026-1-14 13:03 , Processed in 1.033635 second(s), 7 queries , MemCached On.
