查看: 1123|回复: 0
[技术讨论] Networking issue detected错误是什么原因呢
5 金钱 回复本帖可获得 5 金钱奖励! 每人限 1 次(中奖概率 10%)
发表于 2024-11-15 13:03:54 | 显示全部楼层 |阅读模式
我好像就新增了几个加载项,重启就报错了,请问大神这是什么原因进不去系统了?感谢
错误提示
Home Assistant OS detected a networking issue in your setup. As part of the initial setup, Home Assistant OS downloads the latest version of Home Assistant Core. This networking issue prevents this download. The network issue might be DNS related. The currently used DNS service is: 192.168.68.1, 8.8.8.8, 8.8.4.4, 2409:8a3c:2173:31b0::1, 2001:4860:4860::8888, 2001:4860:4860::8844.
To resolve this, you can try a different DNS server. Select one of the options below. Alternatively, change your router configuration to use your own custom DNS server.
GMT+8, 2026-1-14 14:03 , Processed in 0.665254 second(s), 12 queries , MemCached On.
