查看: 1451|回复: 0
[求助] 小米多模网关2,在zigbee2mqtt加入aqara的tvoc监测器报错
发表于 2024-11-12 22:24:09 | 显示全部楼层 |阅读模式
使用小米多模网关2,在zigbee2mqtt加入aqara的tvoc监测器。一直报错。
[backcolor=rgba(var(--bs-danger-rgb),var(--bs-bg-opacity)) !important][size=80%]error
2024-11-12 22:21:00z2m: Failed to configure '0x54ef44100040368c', attempt 1 (Error: Bind 0x54ef44100040368c/1 genPowerCfg from '0x8c739491df8ccf04/1' failed ({"address":39335,"clusterId":32801,"sequence":4} after 10000ms) at Object.start (/app/node_modules/zigbee-herdsman/src/utils/waitress.ts:59:23) at /app/node_modules/zigbee-herdsman/src/adapter/ezsp/adapter/ezspAdapter.ts:324:47 at processTicksAndRejections (node:internal/process/task_queues:95:5) at Queue.execute (/app/node_modules/zigbee-herdsman/src/utils/queue.ts:36:20) at EZSPAdapter.sendZdo (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/adapter/ezspAdapter.ts:278:16) at Endpoint.bind (/app/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:563:30) at Object.bind (/app/node_modules/zigbee-herdsman-converters/src/lib/reporting.ts:42:9) at configure (/app/node_modules/zigbee-herdsman-converters/src/devices/lumi.ts:3476:13) at Object.configure (/app/node_modules/zigbee-herdsman-converters/src/index.ts:205:21) at Configure.configure (/app/lib/extension/configure.ts:130:13))
GMT+8, 2025-12-17 18:50 , Processed in 0.693273 second(s), 7 queries , MemCached On.
