查看: 893|回复: 0
[技术探讨] 更新跳恢复模式 大家帮忙给看看日志是什么原因
发表于 2024-11-6 22:32:15 | 显示全部楼层 |阅读模式
Home Assistant Core
2024-11-06 22:26:18.121 WARNING (MainThread) [homeassistant.components.hassio.handler] Found incompatible HTTP option 'server_host'. Watchdog feature disabled
<font color="#ff0000">2024-11-06 22:27:32.177 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [281473286508832] Unexpected exception</font>
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 168, in async_install
await async_update_addon(self.hass, slug=self._addon_slug, backup=backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 58, in _wrapper
data = await funct(*argv, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 112, in async_update_addon
return await hassio.send_command(
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 541, in send_command
raise HassioAPIError(error.get(ATTR_MESSAGE))
homeassistant.components.hassio.handler.HassioAPIError: 'BackupManager.do_backup_partial' blocked from execution, system is not running - startup
The above exception was the direct cause of the following exception:
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 245, in handle_call_service
response = await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 2761, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2804, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 996, in entity_service_call
single_response = await _handle_entity_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1068, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 154, in async_install
await entity.async_install_with_progress(version, backup)
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 463, in async_install_with_progress
await self.async_install(version, backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 170, in async_install
raise HomeAssistantError(f"Error updating {self.title}: {err}") from err
homeassistant.exceptions.HomeAssistantError: Error updating Zigbee2MQTT: 'BackupManager.do_backup_partial' blocked from execution, system is not running - startup
<font color="#ff0000">2024-11-06 22:27:34.525 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [281473286508832] Unexpected exception</font>
result = await task
<font color="#ff0000">2024-11-06 22:27:39.031 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [281473286508832] Unexpected exception</font>
result = await task
homeassistant.exceptions.HomeAssistantError: Error updating Node-RED: 'BackupManager.do_backup_partial' blocked from execution, system is not running - startup
<font color="#ff0000">2024-11-06 22:27:41.905 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [281473286508832] Unexpected exception</font>
result = await task
homeassistant.exceptions.HomeAssistantError: Error updating ESPHome: 'BackupManager.do_backup_partial' blocked from execution, system is not running - startup
GMT+8, 2026-1-14 08:15 , Processed in 1.196346 second(s), 11 queries , MemCached On.
