查看: 621|回复: 0
[求助] home assistance green 安装错误
发表于 2024-11-4 23:35:36 | 显示全部楼层 |阅读模式
1.将home assistance green 连接网线后,打开app和网站,都出现了以下错误,请问如何解决
错误日志如下:
[15:33:29] INFO: Using udev information from host
[15:33:30] INFO: Starting local supervisor watchdog...
2024-11-04 15:33:38.004 INFO (MainThread) [__main__] Initializing Supervisor setup
2024-11-04 21:33:38.159 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: green
2024-11-04 21:33:38.173 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2024.10.3
2024-11-04 21:33:38.173 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
2024-11-04 21:33:38.446 INFO (SyncWorker_0) [supervisor.docker.manager] Cleanup images: ['ghcr.io/home-assistant/aarch64-hassio-supervisor:2023.10.0']
2024-11-04 21:33:39.889 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
2024-11-04 21:33:39.895 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-11-04 21:33:39.897 INFO (MainThread) [__main__] Setting up Supervisor
2024-11-04 21:33:40.778 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
2024-11-04 21:33:41.027 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
2024-11-04 21:33:41.031 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
2024-11-04 21:33:41.032 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
2024-11-04 21:33:41.034 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
2024-11-04 21:33:41.036 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
2024-11-04 21:33:41.038 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
2024-11-04 21:33:41.041 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
2024-11-04 21:33:41.045 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
2024-11-04 21:33:41.047 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
2024-11-04 21:33:41.050 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
2024-11-04 21:33:41.633 INFO (MainThread) [supervisor.host.services] Updating service information
2024-11-04 21:33:41.646 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2024-11-04 21:33:42.006 INFO (MainThread) [supervisor.host.network] Updating local network information
2024-11-04 21:33:42.125 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
2024-11-04 21:33:42.209 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
2024-11-04 21:33:42.210 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
2024-11-04 21:33:43.189 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.06.0
2024-11-04 21:33:43.248 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2
2024-11-04 21:33:43.274 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
2024-11-04 21:33:43.294 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.06.0
2024-11-04 21:33:43.329 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0
2024-11-04 21:33:43.362 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2023.06.2
2024-11-04 21:33:43.388 INFO (MainThread) [supervisor.plugins.manager] cli does not have the latest version 2024.09.0, updating
2024-11-04 21:33:43.393 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/aarch64-hassio-cli:2023.06.0 to ghcr.io/home-assistant/aarch64-hassio-cli:2024.09.0
2024-11-04 21:33:43.394 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/aarch64-hassio-cli with tag 2024.09.0.
2.购买了home assistance green后,有必要再购买home assistance sky connect吗?(已购买了小米多模网关)
期待大神的解答,万分感谢
GMT+8, 2025-12-17 18:45 , Processed in 1.058107 second(s), 16 queries , MemCached On.
