查看: 6548|回复: 1
[求助] 关于433码,求助
huex 手机认证
发表于 2018-2-7 10:21:56 | 显示全部楼层 |阅读模式
     由于手头有几个可以用射频控制的设备,而且这货还无法用生成的broadlink编码,手头有一个3开, 所以打算学习出来码,然后自己编一下,但搞了好久,一直也搞不明白,到底是什么编码形式,也查了资料,实在看不明白,所以希望大神给指点下
     接收信号的芯片是CMT2110LB  ,发的的芯片被抹了,看不清,
用esp8266 简单得到以下数据。是三个3按键的
Decimal: 7864323 (24Bit) Binary: 011110000000000000000011 Tri-State: not applicable PulseLength: 148 microseconds Protocol: 1
Raw data: 4603,216,424,488,123,488,121,490,120,490,120,185,425,183,427,183,426,183,426,201,410,183,427,217,423,185,455,183,426,215,426,182,427,155,456,182,427,215,426,182,427,182,429,213,427,489,162,477,123,
Decimal: 7864321 (24Bit) Binary: 011110000000000000000001 Tri-State: not applicable PulseLength: 148 microseconds Protocol: 1
Raw data: 4604,188,422,494,147,492,119,492,118,492,119,186,454,156,424,183,427,183,424,183,427,185,426,216,424,182,428,185,427,186,425,182,427,183,427,213,397,214,427,185,425,184,426,215,427,184,427,487,122,
Decimal: 7864322 (24Bit) Binary: 011110000000000000000010 Tri-State: not applicable PulseLength: 149 microseconds Protocol: 1
Raw data: 4631,187,423,522,119,488,121,492,151,459,121,184,425,185,425,185,425,184,425,216,424,184,456,183,427,184,425,183,428,182,426,215,425,183,426,184,427,182,428,217,425,183,426,184,425,489,122,184,426,
    数据形式,尝试转换过二进制,但这个是数据是如何分组的呢,感觉一条数据包含了有好几组的开关一样,有能指点的大神吗,
wktm 手机认证
发表于 2018-9-5 20:41:46 | 显示全部楼层
现在遇见的跟你的一样,很奇怪的射频编码,这货是两路继电器开关,带射频,用博联读出的码是一大大串长数字,不知道怎么用在ttl转发上面,就买个ttl 转串口的卡,读出一组数据 ,再次按压同一个按钮,数字又有变化,很是奇怪,
串口转射频的读码:FD B6 89 08 53 DF
博联的读码: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
用step0766大咖的方法,https://bbs.hassbian.com/thread-1314-1-1.html ,读出的又是
是杜亚管机的,用博联读出来后,发现不行
GMT+8, 2025-12-24 21:35 , Processed in 1.066898 second(s), 8 queries , MemCached On.
