查看: 1268|回复: 0
[求助] 新设备无法登录
发表于 2024-10-30 16:57:38 | 显示全部楼层 |阅读模式
今天清除了下浏览器cookies,然后发现登录会出现这种界面
很长时间没有新添加设备,不知道是何时出现这种情况的
看日志发现应该是这个错误
日志记录器: aiohttp.server
来源: /usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py:448
首次出现: 16:46:03 (1 次总计出现)
上次记录: 16:46:03
Error handling request
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 477, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 559, in _handle
    return await handler(request)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 117, in impl
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 83, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 85, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware
    response = await handler(request)
  File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
    result = await handler(request, **request.match_info)
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 100, in handle_req
    resp = await func(view, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/auth/__init__.py", line 267, in post
    return await self._async_handle_auth_code(hass, data, request)
  File "/usr/src/homeassistant/homeassistant/components/auth/__init__.py", line 315, in _async_handle_auth_code
    refresh_token = await hass.auth.async_create_refresh_token(
  File "/usr/src/homeassistant/homeassistant/auth/__init__.py", line 506, in async_create_refresh_token
    return await self._store.async_create_refresh_token(
TypeError: Voice.async_create_refresh_token() takes from 2 to 8 positional arguments but 9 were given
看看大佬知道怎么回事吗
GMT+8, 2025-12-17 22:15 , Processed in 1.148745 second(s), 13 queries , MemCached On.
