查看: 3333|回复: 14
[求助] 子擎存在传感器Loong该如何加进Xiaomi Gateway 3
发表于 2024-10-23 21:41:29 | 显示全部楼层 |阅读模式
大家好,近期购买的子擎存在传感器Loong,加进Xiaomi Gateway 3后无法显示相关资料,厂牌显示未知,请教该如何设定才能显示如米家app上的调整功能?  先向大家说声谢谢。
如果改用Miot,可以看到其他資訊,但感測器的數據並不能作為自動化的設定,例如自動化的選項中不能單純選擇"當有人..則如何",所以我現在是改成當無人狀態超過1min,則關掉電燈,這樣便會拉長關燈的時間。
2024/10/24-15:23更新:
我參考網上資訊,做了個PY,資料如下,結果訊息都變未知,希望有人可以一起測試看看https://home.miot-spec.com/s/izq.sensor_occupy.ble
from custom_components.xiaomi_gateway3.core.devices import *
DEVICES = [{
    18788: ["izq", "ZQ Occupy Sensor Loong", "izq.sensor_occupy.ble"],
    "spec": [
        BoolConv("occupancy", "binary_sensor", mi="2.p.1078"),
        MathConv("detection_distance", "number", mi="2.p.1", multiply=0.01),
        MathConv("no_one_determine_time", "number", mi="2.p.2", min=0, max=10000),
        MathConv("has_someone_detection-sensitivity", "sensor", mi="2.p.3"),
        MathConv("no_one_detection_sensitivity", "sensor", mi="2.p.4"),
        MathConv("continuous_detection_distance", "sensor", mi="2.p.5"),
        MathConv("illuminance", "sensor", mi="2.p.1005"),
        MathConv("idle_time", "sensor", mi="2.p.1079", multiply=60),  # diagnostic
        MathConv("has_someone_duration", "sensor", mi="2.p.1080"),
        BaseConv("indicator-light", "switch", mi="3.p.1032"),  # config
        BaseConv("battery_level", "sensor", mi="4.p.1003"),
        MapConv("occupancy_status", "sensor", mi="2.p.1078", map={0: "NoOne", 1: " Has One "}),
}] + DEVICES
2024/10/24:
子擎loong PIID資訊:https://home.miot-spec.com/spec/izq.sensor_occupy.ble
我在Devices.py上找到以下子擎Lite的代碼,我試著改改看。
    10356: ["ZiQing", "IZQ Presence Sensor Lite", "IZQ-24", "izq.sensor_occupy.24"],
    "spec": [
        BoolConv("occupancy", "binary_sensor", mi="2.p.1"),
        MathConv("has_someone_duration", "sensor", mi="2.p.3"),
        MathConv("idle_time", "sensor", mi="2.p.4", multiply=60),  # diagnostic
        MathConv("illuminance", "sensor", mi="2.p.5"),
        MathConv("distance", "sensor", mi="2.p.6", multiply=0.01),
        BaseConv("led", "switch", mi="3.p.1"),  # config
        BaseConv("pir", "switch", mi="3.p.3"),
        MathConv("detect_range", "number", mi="3.p.2", min=0, max=8, step=0.1),
        MathConv("enterin_confirm_time", "number", mi="3.p.5", min=0, max=60),
        MapConv("occupancy_status", "sensor", mi="2.p.1", map={0: "NoOne", 1: "EnterIn", 2: "SmallMove", 3: "MicroMove", 4: "Approaching", 5: "MoveAway"}),
发表于 2024-10-23 23:22:29 | 显示全部楼层
比较新的设备需要自己写Converters,论坛有人出过教程,可以参考着自己写一下https://bbs.hassbian.com/thread-17548-1-1.html
发表于 2024-10-24 02:28:42 | 显示全部楼层
同求
发表于 2024-10-24 08:23:09 | 显示全部楼层
插眼学习。
发表于 2024-10-24 09:22:54 | 显示全部楼层
我写过2个电动窗帘的Converters
 楼主| 发表于 2024-10-24 13:43:20 | 显示全部楼层
hungheo 发表于 2024-10-23 23:22
比较新的设备需要自己写Converters,论坛有人出过教程,可以参考着自己写一下https://bbs.hassbian.com/thr ...
謝謝您的幫助,我來研究看看如何寫Converters,如果成功再分享出來!
发表于 2024-10-26 15:19:55 | 显示全部楼层
搞定了吗?
 楼主| 发表于 2024-10-27 01:58:02 | 显示全部楼层
失敗了
前幾天自己試著寫PY的文件,但顯示的資訊都是未知,最後還是先搭配MIOT湊著使用。
DEVICES = [{
    "spec": [
}] + DEVICES
发表于 2024-10-30 13:50:04 | 显示全部楼层
同求,刚买了还在路上。
innx 手机认证
发表于 2024-10-31 01:08:28 | 显示全部楼层
DEVICES = [{
    "spec": [
        BaseConv("illuminance", "sensor", mi="2.p.1005"),
        MapConv("occupancy_status", "sensor", mi="2.p.1078", map={0: "NoOne", 1: "HasOne"}),
        BaseConv("no-one-duration", "sensor", mi="2.p.1079"),
        BaseConv("has-someone-duration", "sensor", mi="2.p.1080")
}] + DEVICES
最小化这样试试呢?Has One 不要空格
黑名单 icstow昵称朝廷心腹
GMT+8, 2025-12-31 22:59 , Processed in 0.297060 second(s), 14 queries , MemCached On.
