查看: 1681|回复: 1
[求助] 惠橘X1S刷esphome ota后插座断电重启
发表于 2024-10-21 10:06:58 | 显示全部楼层 |阅读模式
每次ota更新后插座会断开继电器后重新打开,能否让其不断开?
配置如下:
esphome:
  friendly_name: "x1s"
  platformio_options:
    board_build.bkcrypt_coeffs: "00000000000000000000000000000000"
    board_build.bkota.key: "0123456789ABCDEF0123456789ABCDEF"
    board_build.bkota.iv: "0123456789ABCDEF"
    board_flash.download: "0x132000+0xA6000"
    board_flash.kvs: "0x1D8000+0x8000"
    board_flash.calibration: "0x1E0000+0x1000"
    board_flash.tlv: "0x1E1000+0x1000"
    board_flash.net: "0x1E2000+0x1000"
    board_flash.userdata: "0x1E3000+0x1D000"
bk72xx:
  board: generic-bk7231n-qfn32-tuya
logger:
# web_server:
captive_portal:
mdns:
api:
ota:
wifi:
  ssid: !secret wifi_ssid
  ap:
substitutions:
  voltage_divider: "800.4735172433958"
  current_resistor: "0.0010788674067058845"
  current_multiply: "0.4667266199455673"
preferences:
  flash_write_interval: 10min
status_led:
  pin:
    number: P11
    inverted: True
output:
  - platform: gpio
    pin:
      number: P10
      inverted: True
switch:
  - platform: gpio
    pin: P8
    restore_mode: RESTORE_DEFAULT_OFF
    on_turn_on:
      - output.turn_on: led1
    on_turn_off:
      - output.turn_off: led1
binary_sensor:
- platform: gpio
   pin:
      number: P24
      mode: INPUT_PULLUP
      inverted: true
   filters:
     - delayed_on_off: 100ms
   on_press:
     then:
       - switch.toggle: relay
  - platform: hlw8012
    model: BL0937
    current_resistor: ${current_resistor}
    voltage_divider: ${voltage_divider}
    sel_pin:
      number: P26
      inverted: true
    cf_pin:
      number: P6
      inverted: true
    cf1_pin:
      number: P7
      inverted: true
    current:
      accuracy_decimals: 3
      filters:
          - multiply: ${current_multiply}
    voltage:
      accuracy_decimals: 2
    power:
    energy:
    update_interval: 5s
  - platform: wifi_signal
    update_interval: 1min
  - platform: uptime
发表于 2024-10-21 15:28:25 | 显示全部楼层
要用在服务器、网络设备这些不能随便断电的地方,最好是用硬件来实现,
1、用磁保持继电器(省电)
2、用常闭继电器(省电)
3、以上都做不到的话,继电器驱动电路加1个三极管和1个电阻(费电)
GMT+8, 2025-12-17 18:49 , Processed in 1.008625 second(s), 7 queries , MemCached On.
