查看: 12101|回复: 9
[求助] RM Pro + 接入homeassistant问题
发表于 2018-2-5 23:56:44 | 显示全部楼层 |阅读模式
homeassistant正常运行,可以接入sonoff开关控制,现在想接入rm pro 结果买回来发现是rm pro +,按照论坛里面都教程在configuration.yaml文件里面添加了 屏幕快照 2018-02-05 下午11.57.10.png
这个信息后,在sever里面找不到broadlink都选项啊,试了论坛里面各种方法都不起作用,大神们指导一下啊,谢谢
发表于 2018-2-6 08:40:01 | 显示全部楼层
看日志,有啥错误
★Raspberry + Raspbian + Home Assistant v0.1
★树莓派 + Raspbian系统 + HomeAssistant
https://github.com/huangqian8/homeassistant
发表于 2018-2-6 12:32:25 | 显示全部楼层
domain里有吗?
发表于 2018-2-6 14:33:54 | 显示全部楼层
RM Pro +也是支持的,你先把它IP固定了,再试试。
发表于 2018-2-6 19:01:10 | 显示全部楼层
我的rm pro+没问题,
应该是ip或mac问题吧
 楼主| 发表于 2018-2-7 21:02:07 | 显示全部楼层
bluefire1982 发表于 2018-2-6 08:40
看日志,有啥错误
Log Details (ERROR)
Wed Feb 07 2018 20:59:32 GMT+0800 (CST)
Error while setting up platform broadlink
  File "/srv/homeassistant/lib/python3.4/site-packages/broadlink/__init__.py", line 5, in <module>
    from Crypto.Cipher import AES
  File "/srv/homeassistant/lib/python3.4/site-packages/Crypto/Cipher/__init__.py", line 78, in <module>
    from Crypto.Cipher._mode_ecb import _create_ecb_cipher
  File "/srv/homeassistant/lib/python3.4/site-packages/Crypto/Cipher/_mode_ecb.py", line 29, in <module>
    from Crypto.Util._raw_api import (load_pycryptodome_raw_lib,
  File "/srv/homeassistant/lib/python3.4/site-packages/Crypto/Util/_raw_api.py", line 34, in <module>
    from Crypto.Util.py3compat import byte_string
ImportError: cannot import name 'byte_string'
  File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 189, in _async_setup_platform
    SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
  File "/usr/lib/python3.4/asyncio/tasks.py", line 372, in wait_for
    return fut.result()
  File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
    raise self._exception
  File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
  File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/switch/broadlink.py", line 74, in setup_platform
    import broadlink
  File "/srv/homeassistant/lib/python3.4/site-packages/broadlink/__init__.py", line 7, in <module>
    import pyaes
ImportError: No module named 'pyaes'
咋整啊
发表于 2018-2-8 10:20:32 | 显示全部楼层
python环境问题
import pyaes
以上两条命令都存在问题
 楼主| 发表于 2018-2-8 16:18:19 | 显示全部楼层
bluefire1982 发表于 2018-2-8 10:20
python环境问题
[code]from Crypto.Util.py3compat import byte_string
import pyaes[/ ...
是要装一下python-broadlink吗,还是怎么弄,先生教我
发表于 2020-5-16 14:29:17 | 显示全部楼层
今天在研究怎么添加RM Pro+
发表于 2020-5-17 11:59:40 | 显示全部楼层
winner_0986 发表于 2020-5-16 14:29
今天在研究怎么添加RM Pro+
研究出来带带我
GMT+8, 2025-12-25 08:03 , Processed in 0.056264 second(s), 14 queries , MemCached On.
