查看: 10198|回复: 3
[技术探讨] 求助-homekit 怎么样都显示不了海康摄像头
发表于 2018-2-5 23:23:13 | 显示全部楼层 |阅读模式
本人小白,潜水多日后尝试接入手中的海康摄像头,可是看了各个大神的教程怎么样修改Json都没法显示在homekit 上(可以显示在home assistant),求助各位大神看看我的Json什么问题,ffmpeg插件根据各位大神的教程安装了的。。。另外我有多个海康的摄像头如何同时接入home assistant呢?(曾经尝试放入多段代码,可只是获取最后一条连接摄像头的影像)谢谢!~
    "bridge": {
        "name": "Harry",
        "username": "B8:27:EB:AE:A1:0B",
        "port": 38953,
        "pin": "123-12-312"
    "platforms": [
          "platform": "HomeAssistant",
            "name": "HomeAssistant",
            "host": "http://192.168.2.101:8123",
            "password": "",
            "supported_types": [
                "automation",
                "binary_sensor",
                "climate",
                "cover",
                "device_tracker",
                "fan",
                "group",
                "input_boolean",
                "light",
                "lock",
                "media_player",
                "remote",
                "scene",
                "script",
                "sensor",
                "switch",
                "vacuum"
            "default_visibility": "visible",
            "logging": false,
            "verify_ssl": true
          "platform": "Camera-ffmpeg",
              "cameras": [{
                    "name": "NVR",
                    "videoConfig": {
                                "source": "-rtsp_transport tcp -i rtsp://admin:[email protected]:554/h264/ch1/main/av_stream",
                                "maxStreams": 2,
                                "maxWidth": 1280,
                                "maxHeight": 720,
                                "maxFPS": 30
发表于 2018-4-3 16:46:41 | 显示全部楼层
关注,我也是这个问题 HK上没有图像,HA上有,我是用的树莓派3 安装的hassbian
发表于 2018-7-27 08:01:36 | 显示全部楼层
我的也是什么都没有。、我的是雄迈的。还在坑里
发表于 2018-11-2 14:05:49 | 显示全部楼层
我也是,HK 上没图像,你后来解决了吗?
GMT+8, 2025-12-1 15:16 , Processed in 0.153575 second(s), 11 queries , MemCached On.
