查看: 2995|回复: 11
[求助] 有关gps设备无法接入traccar的问题
hdp
发表于 2024-10-12 08:49:21 | 显示全部楼层 |阅读模式
目前买4个gps了,一个都无法接入,traccar也有日志了,可能哪里没有设置好,请各位帮忙看一下,谢谢
这是服务器的日志,gps是新买的途强ev25
2024-10-12 00:32:58  INFO: [T9f3ebb93] connected
2024-10-12 00:32:58  INFO: [T9f3ebb93: osmand < 223.104.5.254] 787811010868120222789155a0013202003689190d0a
2024-10-12 00:32:58  INFO: [T9f3ebb93: osmand > 223.104.5.254] HTTP/1.1 400 Bad Request\r\ncontent-length: 0\r\n\r\n
2024-10-12 00:37:22  INFO: [T9f3ebb93: osmand < 223.104.5.254] 787811010868120222789155a0013202003798900d0a
2024-10-12 00:37:22  INFO: [T9f3ebb93] disconnected
2024-10-12 00:37:45  INFO: [T8eb76e02] connected
2024-10-12 00:37:45  INFO: [T8eb76e02: osmand < 223.104.5.254] 787811010868120222789155a0013202003971ee0d0a
2024-10-12 00:37:45  INFO: [T8eb76e02: osmand > 223.104.5.254] HTTP/1.1 400 Bad Request\r\ncontent-length: 0\r\n\r\n
2024-10-12 00:39:42  INFO: [T8eb76e02: osmand < 223.104.5.254] 787811010868120222789155a0013202003a43750d0a
2024-10-12 00:39:43  INFO: [T8eb76e02] disconnected
服务器添加了途强的imei
一直显示没有上线,
是哪里的问题,我要怎么设置
hdp
 楼主| 发表于 2024-10-12 08:57:08 | 显示全部楼层
2024-10-12 00:54:19  INFO: [Td5ed002c] connected
2024-10-12 00:54:19  INFO: [Td5ed002c: osmand < 223.104.5.254] 787811010868120222789155a0013202005d54cc0d0a
2024-10-12 00:54:19  INFO: [Td5ed002c: osmand > 223.104.5.254] HTTP/1.1 400 Bad Request\r\ncontent-length: 0\r\n\r\n
2024-10-12 00:54:29  INFO: [Td5ed002c: osmand < 223.104.5.254] 787811010868120222789155a0013202005e66570d0a
2024-10-12 00:54:36  INFO: Stopping server...
2024-10-12 00:54:53  INFO: Operating system name: Linux version: 6.1.0-20-cloud-amd64 architecture: amd64
2024-10-12 00:54:54  INFO: Java runtime name: OpenJDK 64-Bit Server VM vendor: Eclipse Adoptium version: 21.0.4+7-LTS
2024-10-12 00:54:54  INFO: Memory limit heap: 235mb non-heap: 0mb
2024-10-12 00:54:54  INFO: Character encoding: UTF-8
2024-10-12 00:54:54  INFO: Version: 6.4
2024-10-12 00:54:54  INFO: Starting server...
2024-10-12 00:54:54  INFO: HikariPool-1 - Starting...
2024-10-12 00:54:57  INFO: HikariPool-1 - Added connection conn0: url=jdbc:h2:./data/database user=SA
2024-10-12 00:54:57  INFO: HikariPool-1 - Start completed.
2024-10-12 00:54:57  INFO: Set default schema name to PUBLIC
2024-10-12 00:54:57  INFO: Clearing database change log checksums
2024-10-12 00:54:58  INFO: Successfully acquired change log lock
2024-10-12 00:54:58  INFO: Successfully released change log lock
2024-10-12 00:55:03  INFO: Reading from PUBLIC.DATABASECHANGELOG
2024-10-12 00:55:04  INFO: Reading from PUBLIC.DATABASECHANGELOG
2024-10-12 00:55:04  INFO: UPDATE SUMMARY
2024-10-12 00:55:04  INFO: Run:                          0
2024-10-12 00:55:04  INFO: Previously run:              49
2024-10-12 00:55:04  INFO: Filtered out:                 0
2024-10-12 00:55:04  INFO: -------------------------------
2024-10-12 00:55:04  INFO: Total change sets:           49
2024-10-12 00:55:04  INFO: Update summary generated
2024-10-12 00:55:04  INFO: Successfully released change log lock
2024-10-12 00:55:04  INFO: Command execution complete
2024-10-12 00:55:04  INFO: Health check enabled with period 480000
服务器都重启了还是显示400
防火墙都关闭了
论坛风云人物
发表于 2024-10-12 09:29:10 | 显示全部楼层
Traccar服务端启动是正常的,估计是你的途强ev25没设置好数据发送到服务器端的地址
1、设置路由器8082(web),5023(设备),5055(安卓)端口开放给服务器端IP
2、数据库用户名在数据库的权限设置全域
3、原来的途强服务器地址:server,1,gpsdev.jimicloud.com,21100,0#修改如下:
途强ev25设备上插上手机的SIM卡,用另外的手机给这个途强ev25设备上的手机号码发送信息:server,1,公网域名,5023,0#(也可以是:server,0,公网IP,公网端口,0#),如有短信回复OK表示设置成功。
祝你好运!
hdp
 楼主| 发表于 2024-10-12 09:45:06 | 显示全部楼层
1、设置路由器8082(web) ...
感谢版主,是我的端口设置错误
我一直以为端口是android的apk端口,所以都是用的5055端口,
我把短信的5055设置为5023后一下就成功了。
再次感谢!
我还有另外3个gps设备,在研究一下。
hdp
 楼主| 发表于 2024-10-12 11:05:47 | 显示全部楼层
已经可以上线了,还有一台主板丝印上印着ak-gt02-v7.0 外壳写着4g09的gps暂时不知道怎么设置
发表于 2024-10-12 13:19:50 | 显示全部楼层
想问一下,你用的是什么品牌的GPS
hdp
 楼主| 发表于 2024-10-13 01:54:21 | 显示全部楼层
途强ev25
另外一个图片类似这个 Screenshot_2024-10-13-01-55-47-43_090d9ae461b065ca11c329abb9cd0d70.png
发表于 2024-10-13 04:58:08 | 显示全部楼层
突然想起来,以前买过一个银尔达的4g gps模块,60多块带360兆/年流量
因为家里有公网ip,直接开放mqtt服务器的端口,按照说明书去配置好mqtt服务器的地址,然后mqtt就直接能收到gps坐标了
hdp
 楼主| 发表于 2024-10-13 05:05:27 | 显示全部楼层
羡慕家宽有公网
我的traccar跑在gcp上
发表于 2024-10-19 09:05:53 | 显示全部楼层
hdp 发表于 2024-10-13 05:05
羡慕家宽有公网
我的traccar跑在gcp上
gcp大神?是不是挂咸鱼了
GMT+8, 2025-12-19 20:41 , Processed in 1.466421 second(s), 13 queries , MemCached On.
