查看: 1388|回复: 4
[已解决] 升级10.1后nodered错误
发表于 2024-10-10 22:21:52 | 显示全部楼层 |阅读模式
今天手贱升级了10.1
nodered一直报错
Setup failed for custom integration 'nodered': Unable to import component: cannot import name 'async_get_default_agent' from 'homeassistant.components.conversation.default_agent' (/usr/src/homeassistant/homeassistant/components/conversation/default_agent.py)
Detected blocking call to import_module with args ('custom_components.nodered',) in /usr/src/homeassistant/homeassistant/loader.py, line 1067: ComponentProtocol, importlib.import_module(self.pkg_path) inside the event loop; This is causing stability issues. Please create a bug report at https://github.com/home-assistan ... s%3Aopen+is%3Aissue For developers, please see https://developers.home-assistan ... ions/#import_module Traceback (most recent call last): File "<frozen runpy>", line 198, in _run_module_as_main File "<frozen runpy>", line 88, in _run_code File "/usr/src/homeassistant/homeassistant/__main__.py", line 223, in <module> sys.exit(main()) File "/usr/src/homeassistant/homeassistant/__main__.py", line 209, in main exit_code = runner.run(runtime_conf) File "/usr/src/homeassistant/homeassistant/runner.py", line 189, in run return loop.run_until_complete(setup_and_run_hass(runtime_config)) File "/usr/local/lib/python3.12/asyncio/base_events.py", line 674, in run_until_complete self.run_forever() File "/usr/local/lib/python3.12/asyncio/base_events.py", line 641, in run_forever self._run_once() File "/usr/local/lib/python3.12/asyncio/base_events.py", line 1990, in _run_once handle._run() File "/usr/local/lib/python3.12/asyncio/events.py", line 88, in _run self._context.run(self._callback, *self._args) File "/usr/src/homeassistant/homeassistant/setup.py", line 165, in async_setup_component result = await _async_setup_component(hass, domain, config) File "/usr/src/homeassistant/homeassistant/setup.py", line 334, in _async_setup_component component = await integration.async_get_component() File "/usr/src/homeassistant/homeassistant/loader.py", line 1019, in async_get_component comp = self._get_component() File "/usr/src/homeassistant/homeassistant/loader.py", line 1067, in _get_component ComponentProtocol, importlib.import_module(self.pkg_path)
更新“Node-RED Companion”为4.1.1后恢复正常
HomeAssistant
发表于 2024-10-11 08:40:22 | 显示全部楼层
在hacs中更新下Nodered的集成试试
 楼主| 发表于 2024-10-11 20:29:09 | 显示全部楼层
hacs没有提示有更新,而且,我是加载项加载的,也没提示有更新,v18.1.1
HomeAssistant
发表于 2024-10-12 08:20:24 | 显示全部楼层
现在解决了吗,没解决的话,在hacs手动检查下Nodered更新试试
 楼主| 发表于 2024-10-12 10:31:42 | 显示全部楼层
没呢,今天升级10.2也不行,在加载项把nodered已经删除了。但是在设备里,删不掉nodered
GMT+8, 2025-12-17 16:53 , Processed in 1.069752 second(s), 6 queries , MemCached On.
