查看: 1631|回复: 1
[流程系列] node-red新增或更新节点一直失败
发表于 2024-10-10 13:53:39 | 显示全部楼层 |阅读模式
node-red现在新增节点一直失败,在已经安装的机器上更新节点也失败。看着像是网络连接问题,有啥解决办法么。网上有说切换淘宝源的,怎么进入node-red的命令行?=========================================================2024-10-10T04:23:22.796Z 安装 : node-red-node-mysql 2.0.0
2024-10-10T04:23:22.845Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --omit=dev --engine-strict node-red-node-mysql@2.0.0
2024-10-10T04:54:09.252Z [err] npm error code ECONNRESET
2024-10-10T04:54:09.252Z [err] npm error syscall read
2024-10-10T04:54:09.252Z [err] npm error errno ECONNRESET
2024-10-10T04:54:09.253Z [err] npm error network request to https://registry.npmjs.org/safer-buffer/-/safer-buffer-2.1.2.tgz failed, reason: read ECONNRESET
2024-10-10T04:54:09.253Z [err] npm error network This is a problem related to network connectivity.
2024-10-10T04:54:09.253Z [err] npm error network In most cases you are behind a proxy or have bad network settings.
2024-10-10T04:54:09.253Z [err] npm error network If you are behind a proxy, please make sure that the
2024-10-10T04:54:09.253Z [err] npm error network 'proxy' config is set properly.  See: 'npm help config'
2024-10-10T04:54:09.254Z [err]
2024-10-10T04:54:09.254Z [err] npm error A complete log of this run can be found in: /root/.npm/_logs/2024-10-10T04_23_22_929Z-debug-0.log
2024-10-10T04:54:09.258Z rc=1
发表于 2024-10-11 23:58:59 | 显示全部楼层
宿主机架云梯
GMT+8, 2025-12-17 04:14 , Processed in 0.046277 second(s), 6 queries , MemCached On.
