查看: 8062|回复: 3
docker 0.62 就是发现不了小米空气净化器
发表于 2018-2-4 21:59:21 | 显示全部楼层 |阅读模式
之前都是好的,现在用ubuntu装了docker装了hassio就是发现不了小米空气净化器2018-02-04 21:52:41 ERROR (MainThread) [homeassistant.components.fan] xiaomi_miio: Error on device update!Traceback (most recent call last):  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py", line 397, in _async_add_entity    yield from entity.async_device_update(warning=False)  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 306, in async_device_update    yield from self.async_update()  File "/config/custom_components/fan/xiaomi_miio.py", line 256, in async_update    ATTR_AVERAGE_AIR_QUALITY_INDEX: state.average_aqi,AttributeError: 'AirPurifierStatus' object has no attribute 'average_aqi'
noel
发表于 2018-2-5 01:04:03 | 显示全部楼层
去降级construct
pip3 install construct==2.8.22
 楼主| 发表于 2018-2-5 11:09:33 来自手机 | 显示全部楼层
noel 发表于 2018-2-5 01:04
去降级construct
降级是在hassio的ssh里吗?因为安装ubuntu时安装了openssh,所以不太懂,ubuntu的ssh和hassio的ssh是不是同一个东西?在docker里停止ubuntu的ssh才能打开hassio的ssh,而hassio的ssh又无法使用pip命令
noel
发表于 2018-2-5 16:09:43 | 显示全部楼层
对,hassio的ssh里面降级~
GMT+8, 2026-1-8 08:09 , Processed in 0.527948 second(s), 8 queries , MemCached On.
