查看: 2550|回复: 2
[技术探讨] 来位 大神 教一下 lifesmart 改 万能遥控器的教程!!
发表于 2024-10-3 22:18:57 | 显示全部楼层 |阅读模式
lifesmart 超级碗 16包邮 安装教程 已经刷了esphome 现在遇到一个问题!希望大神带带路!
Processing lifesmart (board: esp01_1m; framework: arduino; platform: platformio/[email protected])--------------------------------------------------------------------------------HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB FlashDependency Graph|-- ESPAsyncTCP-esphome @ 2.0.0|-- ESPAsyncWebServer-esphome @ 3.2.2|-- DNSServer @ 1.1.1|-- ESP8266WiFi @ 1.0|-- ESP8266mDNS @ 1.2|-- noise-c @ 0.1.6|-- ArduinoJson @ 6.18.5Compiling .pioenvs/lifesmart/src/main.cpp.oLinking .pioenvs/lifesmart/firmware.elfRAM:   [=====     ]  46.8% (used 38364 bytes from 81920 bytes)Flash: [======    ]  59.7% (used 610937 bytes from 1023984 bytes)Building .pioenvs/lifesmart/firmware.binesp8266_copy_factory_bin([".pioenvs/lifesmart/firmware.bin"], [".pioenvs/lifesmart/firmware.elf"])esp8266_copy_ota_bin([".pioenvs/lifesmart/firmware.bin"], [".pioenvs/lifesmart/firmware.elf"])========================= [SUCCESS] Took 11.27 seconds =========================INFO Successfully compiled program.INFO Connecting to 192.168.3.159INFO Uploading /data/build/lifesmart/.pioenvs/lifesmart/firmware.bin (615088 bytes)INFO Compressed to 418208 bytesERROR Error binary size: Error: ESP does not have enough space to store OTA file. Please try flashing a minimal firmware (remove everything except ota)
提示 esp 没有足够的 空间!!
现在 只成功加入一个BENQ的遥控器
帮我看看 谢谢
button:
  - platform: template
    icon: mdi:power
    on_press:
      - remote_transmitter.transmit_nec:
          address: 0x3000
          command: 0xFD02
          command_repeats: 1
    icon: mdi:SmartEco
    on_press:
          address: 0x3000
          command: 0xCF30
          command_repeats: 1
    icon: mdi:Meun
    on_press:
          address: 0x3000
          command: 0xF00F
          command_repeats: 1
    icon: mdiower
    on_press:
          address: 0x4CB3
          command: 0x23DC
          command_repeats: 1
    icon: mdi:Enter
    on_press:
          address: 0x4CB3
          command: 0x31CE
          command_repeats: 1
    icon: mdi:CH_UP
    on_press:
          address: 0x4CB3
          command: 0x7A85
          command_repeats: 1
    icon: mdi:CH_DOWN
    on_press:
          address: 0x4CB3
          command: 0x7986
          command_repeats: 1
后面,准备还要加入空调 风扇 hk1 天龙公共遥控器。
BENQ遥控器 加入进去后 后面加入IPTV电视盒子 效验都没有问题
flash还有40%空间
但是最后提示空间不足!!
发表于 2024-10-3 23:48:43 | 显示全部楼层
直接在ha里发射  这样就不需要写入固件了
 楼主| 发表于 2024-10-4 09:38:59 | 显示全部楼层
用smartir来实现吗??看了半天没看懂
GMT+8, 2026-1-14 04:36 , Processed in 0.344062 second(s), 7 queries , MemCached On.
