楼主:
[基础教程] (20180630更新)Ubuntu安装HomeAssistant教程(ubuntu17.10无坑版)
发表于 2017-8-10 13:31:25 | 显示全部楼层
ejohn 发表于 2017-8-9 18:28
在哪里设置爬墙?
这个你要自己去找了,帮不了你
发表于 2017-8-13 12:06:06 | 显示全部楼层
添加小米网关出错的同学看过来
先进虚拟环境
#更换用户
sudo su -s /bin/bash homeassistant
#切换目录,创建并进入虚拟环境
cd /srv/homeassistant
python3 -m venv homeassistant_venv
source /srv/homeassistant/homeassistant_venv/bin/activate
#执行PyCrypto安装
pip install --ignore-installed PyCrypto==2.6.1
安装一下这个软件包就OK了
rray
发表于 2017-8-13 22:07:33 来自手机 | 显示全部楼层
命令太多了吧
发表于 2017-8-14 18:11:39 | 显示全部楼层
无论是虚拟机、还是直接在电脑安装全新系统,安装了N遍,无奈到了这步老是出错:
#设置HomeAssistant开机启动
sudo systemctl enable [email protected]
提示:Failed to execute opration: Invalid argument
快要崩溃了
rray
发表于 2017-8-16 23:18:54 | 显示全部楼层
homeassistant@Orangepi:/srv$ cd /srv/homeassistant
homeassistant@Orangepi:/srv/homeassistant$ python3 -m venv homeassistant_venv
The virtual environment was not created successfully because ensurepip is not
available.  On Debian/Ubuntu systems, you need to install the python3-venv
package using the following command.
    apt-get install python3-venv
You may need to use sudo with that command.  After installing the python3-venv
package, recreate your virtual environment.
Failing command: ['/srv/homeassistant/homeassistant_venv/bin/python3', '-Im', 'ensurepip', '--upgrade', '--default-pip']
homeassistant@Orangepi:/srv/homeassistant$ source /srv/homeassistant/homeassistant_venv/bin/activate
bash: /srv/homeassistant/homeassistant_venv/bin/activate: No such file or directory
homeassistant@Orangepi:/srv/homeassistant$ pip install --upgrade pip
bash: pip: command not found
homeassistant@Orangepi:/srv/homeassistant$ pip3 install netdisco
bash: pip3: command not found
按着步骤来的,怎么会这样呢?command not found
 楼主| 发表于 2017-8-16 23:49:47 | 显示全部楼层
homeassistant@Orangepi:/srv/homeassistant$ python ...
运行一下这个命令:sudo apt-get install python3-venv
再执行后面的操作
发表于 2017-8-18 00:26:05 | 显示全部楼层
非常详细,谢谢大神分享!!!
发表于 2017-8-21 00:59:29 | 显示全部楼层
不错的教程,,感谢楼主。。。。。
czde
发表于 2017-8-21 01:07:33 | 显示全部楼层
谢谢大佬////
教程狂人论坛风云人物
发表于 2017-8-21 01:09:41 | 显示全部楼层
早就该出了。。。
GMT+8, 2025-12-16 14:05 , Processed in 0.508331 second(s), 10 queries , MemCached On.
