楼主:
[基础教程] (20180630更新)Ubuntu安装HomeAssistant教程(ubuntu17.10无坑版)
发表于 2018-2-6 10:37:13 | 显示全部楼层
感谢分享感谢分享
发表于 2018-2-6 16:39:11 | 显示全部楼层
学习学习
发表于 2018-2-7 13:49:50 | 显示全部楼层
谢谢分享
发表于 2018-2-7 14:06:58 | 显示全部楼层
膜拜大神
发表于 2018-2-7 14:10:07 | 显示全部楼层
支持无坑
anda 手机认证
发表于 2018-2-7 21:21:15 | 显示全部楼层
谢谢分享,
准备用x86装
anda 手机认证
发表于 2018-2-7 21:42:23 | 显示全部楼层
老大,执行pip install netdisco 的时候有以下报错,不知道有影响没?
  Downloading urllib3-1.22-py2.py3-none-any.whl (132kB)
    100% |████████████████████████████████| 133kB 10kB/s
Building wheels for collected packages: enum-compat, netifaces
  Running setup.py bdist_wheel for enum-compat ... error
  Complete output from command /srv/homeassistant/homeassistant_venv/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-10ceiyxw/enum-compat/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/tmpgq097fv_pip-wheel- --python-tag cp35:
  usage: -c [global_opts] cmd1 [cmd1_opts] [cmd2 [cmd2_opts] ...]
     or: -c --help [cmd1 cmd2 ...]
     or: -c --help-commands
     or: -c cmd --help
  error: invalid command 'bdist_wheel'
  Failed building wheel for enum-compat
  Running setup.py clean for enum-compat
  Running setup.py bdist_wheel for netifaces ... error
  Complete output from command /srv/homeassistant/homeassistant_venv/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-10ceiyxw/netifaces/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/tmpf6_hwfkfpip-wheel- --python-tag cp35:
     or: -c cmd --help
  Failed building wheel for netifaces
  Running setup.py clean for netifaces
Failed to build enum-compat netifaces
Installing collected packages: six, enum-compat, netifaces, zeroconf, chardet, idna, certifi, urllib3, requests, netdisco
  Running setup.py install for enum-compat ... done
  Running setup.py install for netifaces ... done
Successfully installed certifi-2018.1.18 chardet-3.0.4 enum-compat-0.0.2 idna-2.6 netdisco-1.2.4 netifaces-0.10.6 requests-2.18.4 six-1.11.0 urllib3-1.22 zeroconf-0.19.1
发表于 2018-2-8 13:10:50 | 显示全部楼层
这个顶起来
发表于 2018-2-9 10:20:02 | 显示全部楼层
学习下看看
发表于 2018-2-9 17:18:09 | 显示全部楼层
求教 如果是16.04 改参照哪个教程好一点???
GMT+8, 2025-12-25 23:21 , Processed in 0.060389 second(s), 10 queries , MemCached On.
